    SOLVED no read-out from i2c whitebalance
      Seka last edited by
      I am having troubles with variations in supposedly whitebalance and image brightnes.
      I changed to same model but different RPI 4B and still use this code:
      import D_mipicamera as Dcam
      camera = Dcam.mipi_camera()
      camera.init_camera()
      import os
      status = os.system('sh ./veye_mipi_i2c.sh -w -f cameramode -p1 0x0 -b 10')
      print status
      status = os.system('sh ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFC -p1 0x00 -b 10')
      #print status
      ##turn off automatic exposure
      status = os.system('sh ./veye_mipi_i2c.sh -w -f agc -p1 0 -b 10')
      print status
      ##turn off white balance
      status = os.system('sh ./veye_mipi_i2c.sh -w -f wbmode -p1 0x1b -b 10')
      print status
      status = os.system('sh ./veye_mipi_i2c.sh -w -f lowlight -p1 0x09  -b 10')
      print status
      directory="/home/pi/testmipi/"
      date = datetime.datetime.now().strftime("%m_%d_%Y_%H_%M_%S")
      frame = camera.capture(encoding = 'jpeg')
      camera.release_buffer(frame)
      del frame
      time.sleep(1)
      frame.as_array.tofile((directory)+"nm590"+ date + ".jpg")
      del frame
      But I still get different image brightness.
      I tried to read-out the whitebalance value with
      ./veye_mipi_i2c.sh -r -f wbmode -b 10
      But i dont get any return value.
      What can be the problem?
      Do I have to install the camera again if it is the same disk image but another (same model) Pi?
      I can read-out the value for mshutter without problems...
      Another question: Is there a limit how often I can change the camera settings
      I realized that the camera settings have to be set each time that the RPI boots. Is there a way to write the camera settings permanently?
      Many thanks
        Seka @Seka last edited by
        @seka
        I can read-out mshuttr, daynightmode etc. perfectly.. only wbmode there is no return.
        Just executes the command and nothing
          @seka
          hdver is 0x 3 amd devid is 0x 6
            veye_xumm @Seka last edited by
            @seka
            Please check if you veye_mipi_i2c.sh is the latest version.
            I'm sorry, VEYE series can not support this.
              Seka @veye_xumm last edited by
              @veye_xumm Thank you Xu, downloaded the new file and now it is working like a treat!
