    SOLVED Setting YUV-sequence CSSC132
      lubertRoft last edited by
      is it possible to change the YUV-sequence of the CSSC132?
      Using the given command ./veye_mipi_i2c.sh -w -f yuvseq I get the correct value "YUYV" reading it out in the command line, but the output is still in "UYVY" sequence.
      Why isn't it a cs_mipi_i2c.sh command?
        veye_xumm @lubertRoft last edited by
        @lubertroft
        hi,
        http://wiki.veye.cc/index.php/CS-MIPI-SC132_version_log
        yuyv is supported in this version .
        Because it is CS series, of course cs_mipi_i2c.sh is the corresponding script.
        http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#yuvseq
        1 Reply Last reply Reply Quote 1
          Thank you, that solved the problem.
          It would be helpful if you could update that in point 3.45 on the site: http://wiki.veye.cc/index.php/CS-MIPI-X_i2c
          Regards
