    SOLVED jetpack4.5 use sc132
      npcdna last edited by
      My tx2 use Jetson Jetpack 4.5.1, i can use Jetpack 4.5 cssc132 Drivers, i can detect /dev/video0 after i upgraded dsp, but i can't connect internet. so i changed my tx2 system. i reinstall jetpack 4.5, but when i upgraded dsp, i can't use Jetpack 4.5 cssc132 Drivers, i cannot detect /dev/video0, i cannot detect demeg | cssc132, when i check directory, i found my dsp driver directory is " ls /proc/device-tree/i2c@3180000/tca9548@77/i2c@_" , is not "ls /proc/device-tree/i2c@3180000/tca9548@70/i2c@_", how can i solve this problem, need i reinstall tx2 system?
        veye_xumm @npcdna last edited by
        @npcdna
        Hi,I just checked this file and it works fine here.
        And my device tree is /proc/device-tree/i2c@3180000/tca9548@70 here. I think it's some hardware differences, let's ignor the 70/77 first.
        pls show me the results of cmd below :
        cat /etc/nv_tegra_release
        ls /proc/device-tree/i2c@3180000/tca9548@77/i2c@*
        ls /sys/bus/i2c/drivers/
        Regards!
          @npcdna
          Has the problem been solved?
