    UNSOLVED OrangePi cm5-tablet RAW-MIPI-SC132M
    Rockchip App camera
    3018
      mparem last edited by
      Hello, I am trying to connect veye RAW-MIPI-SC132M to OrangePi cm5-tablet.
      Following the instructions from https://github.com/veyeimaging/rk35xx_orangepi/tree/main/linux,
      I cloned:
      1. https://github.com/orangepi-xunlong/OrangePi_Build
      2. https://github.com/veyeimaging/rk35xx_orangepi/tree/main
      3. https://github.com/veyeimaging/rk35xx_veye_bsp
      4. ran an empty build to generate the base structure (sudo ./build.sh)
      5. copied the drivers from the bsp repo
      6. copied the configs
      7. modified the device tree files:
        7.1) rk3588s-orangepi-cm5-tablet.dts:
      #include "rk3588s-orangepi-cm5-tablet-lcd.dtsi"
      #include "rk3588s-orangepi-cm5-tablet-camera1.dtsi"
      //#include "rk3588s-orangepi-cm5-tablet-camera2.dtsi"
      #include "rk3588s-orangepi-cm5-tablet-camera2-veyemv.dtsi"
      #include "rk3588s-orangepi-cm5-tablet-camera3.dtsi"
      7.2) rk3588s-orangepi-cm5-tablet-camera2-veyemv.dtsi:
      // SPDX-License-Identifier: (GPL-2.0+ OR MIT)
       * Copyright (c) 2021 Rockchip Electronics Co., Ltd.
      &csi2_dcphy0 {
      	status = "okay";
      	ports {
      		#address-cells = <1>;
      		#size-cells = <0>;
      		port@0 {
      			reg = <0>;
      			#size-cells = <0>;
      			mipi_in_dcphy_0: endpoint@0 {
      				reg = <0>;
      				remote-endpoint = <&mvcam_out2>;
      				data-lanes = <1 2>;
      			mipi_in_dcphy_1: endpoint@1 {
      				reg = <0>;
      				remote-endpoint = <&imx219_out_1>;
      				data-lanes = <1 2>;
      		port@1 {
      			reg = <1>;
      			#size-cells = <0>;
      			csidcphy0_out: endpoint@0 {
      				reg = <0>;
      				remote-endpoint = <&mipi0_csi2_input>;
      &i2c6 {
      	status = "okay";
      	mvcam_2: mvcam@36 {
      		status = "okay";
      	        compatible = "veye,mvcam";
      		reg = <0x36>;
      		clocks = <&ext_cam_ov5647_clk>;
      		clock-names = "ext_cam_ov5647_clk";
      		pwdn-gpios = <&gpio4 RK_PA7 GPIO_ACTIVE_HIGH>;
      		rockchip,camera-module-index = <1>;
      		rockchip,camera-module-facing = "front";
      		port {
      			veyecam2m_out2: endpoint {
      			        remote-endpoint = <&mipi_in_dcphy_0>;
      			        data-lanes = <1 2>;
      	imx219_cam2: imx219-cam2@10 {
      	        status = "disabled";
      	        compatible = "sony,imx219";
      	        reg = <0x10>;
      	        pwdn-gpios = <&gpio4 RK_PA7 GPIO_ACTIVE_LOW>;
      	        rockchip,camera-module-name = "rpi-camera-v2";
      	        rockchip,camera-module-lens-name = "default";
      	        port {
      	                imx219_out_1: endpoint {
      			        remote-endpoint = <&mipi_in_dcphy_1>;
      	                        data-lanes = <1 2>;
      &mipi0_csi2 {
      	status = "okay";
      	ports {
      		#size-cells = <0>;
      		port@0 {
      			reg = <0>;
      			#size-cells = <0>;
      			mipi0_csi2_input: endpoint@1 {
      				reg = <1>;
      				remote-endpoint = <&csidcphy0_out>;
      		port@1 {
      			reg = <1>;
      			#size-cells = <0>;
      			mipi0_csi2_output: endpoint@0 {
      				reg = <0>;
      				remote-endpoint = <&cif_mipi_in0>;
      &rkcif_mipi_lvds {
      	port {
      		cif_mipi_in0: endpoint {
      			remote-endpoint = <&mipi0_csi2_output>;
      &rkcif_mipi_lvds_sditf {
      	port {
      		mipi_lvds_sditf: endpoint {
      			remote-endpoint = <&isp1_in1>;
      &rkisp1_vir0 {
      	port {
      		#size-cells = <0>;
      		isp1_in1: endpoint@0 {
      			reg = <0>;
      			remote-endpoint = <&mipi_lvds_sditf>;
      sudo dmesg | grep mvcam does not output
      mvcam 1-003b: camera is: RAW-MIPI-SC132M
      mvcam 1-003b: firmware version: 0x1040000
      instead, I see
      platform csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/mvcam@36
      Any help would be much appreciated.
      Best regards,
      Mikhail
        veye_xumm @mparem last edited by
        @mparem
        1. mvcam's i2c address is 0x3b, not 0x36.
        2. please set rkcif_mipi_lvds's status as okay.
        good luck!
          mparem @veye_xumm last edited by
          Dmesg | grep mvcam:
          csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/mvcam@3b
          @veye_xumm said in OrangePi cm5-tablet RAW-MIPI-SC132M:
          @mparem
          good luck!
            mparem @mparem last edited by
            update: I modified the device tree a few times, and reached a different error message:
            i2c-6: Failed to create I2C device for /i2c@fec80000/mvcam@3b
            How can I verify that the drivers were correctly installed?
            neither lsmod nor less /proc/modules show anything veye-related
              @mparem
              Because on the RK platform, the mvcam driver needs to be built into the kernel, it will not appear in the lsmod list.
              Please send me your current DTS and the related error so I can take a look.
              The cam2 interface on the tablet corresponds to dcphy0 and i2c6, which is correct.
                mparem last edited by mparem
                tablet_3b2.dts.txt
                This is the decompiled dts, which I modified (set i2c address to 0x3b and changed compatibility to veye,mvcam), compiled, then moved back into /boot/dtb*/rockchip/rk3588s-orangepi-cm5-tablet.dtb (faster than recompiling with orangepi-build)
                sudo dmesg | grep ov5647
                [    6.594040] i2c i2c-6: of_i2c: modalias failure on /i2c@fec80000/ov5647-cam2@36
                [    6.594051] i2c i2c-6: Failed to create I2C device for /i2c@fec80000/ov5647-cam2@36
                [    6.594128] platform csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/ov5647-cam2@3b
                [    6.607375] i2c i2c-7: of_i2c: modalias failure on /i2c@fec90000/ov5647-cam3@36
                [    6.607381] i2c i2c-7: Failed to create I2C device for /i2c@fec90000/ov5647-cam3@36
                [    6.607412] platform csi2-dcphy1: Fixed dependency cycle(s) with /i2c@fec90000/ov5647-cam3@3b
                sudo dmesg | grep csi2-dcphy0
                [    5.600344] platform csi2-dcphy0: Fixed dependency cycle(s) with /mipi0-csi2
                [    6.824192] rockchip-csi2-dphy csi2-dcphy0: csi2 dphy0 probe successfully!
                sudo dmesg | grep i2c
                [    5.612002] platform fed80000.phy: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22/connector
                [    6.408625] platform fc000000.usb: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22
                [    6.423672] i2c_dev: i2c /dev entries driver
                [    6.584542] platform csi2-dphy0: Fixed dependency cycle(s) with /i2c@fea90000/ov13850-1@10
                [    6.584625] i2c i2c-1: 1 i2c clients have been registered at 0x0c
                [    6.584679] platform csi2-dphy0: Fixed dependency cycle(s) with /i2c@fea90000/ov13855-1@36
                [    6.594013] i2c i2c-6: of_i2c: modalias failure on /i2c@fec80000/imx219-cam2@10
                [    6.594028] i2c i2c-6: Failed to create I2C device for /i2c@fec80000/imx219-cam2@10
                [    6.607497] platform csi2-dcphy1: Fixed dependency cycle(s) with /i2c@fec90000/imx219-cam3@10
                [    6.708500] [Awinic] [1-0059]aw87xxx_i2c_probe: succeed, dev_index=[0], g_aw87xxx_dev_cnt= [1]
                [    6.709515] [Awinic] [1-005a]aw87xxx_i2c_probe: succeed, dev_index=[1], g_aw87xxx_dev_cnt= [2]
                  @mparem
                  Please post dmesg | grep mvcam output here.
                    [sudo] password for orangepi:
                    [    6.581083] platform csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/mvcam2@3b
                    sudo i2cdetect -y 6
                         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
                    00:                         -- -- -- -- -- -- -- --
                    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    20: -- -- UU -- -- -- -- -- -- -- -- -- -- -- -- --
                    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    60: -- -- -- -- -- -- -- -- -- -- 6a -- -- -- -- --
                    70: -- -- -- -- -- -- -- --
                      @mparem said in OrangePi cm5-tablet RAW-MIPI-SC132M:
                      I haven't used this method before, and I didn't quite understand your source code.
                      Now it seems the issue might still be with the DTS. I suggest you try editing the DTS source code using conventional methods.
                        rk3588s-orangepi-cm5-tablet.dts.txt
                        rk3588s-orangepi-cm5-tablet-camera2-veyemv.dtsi.txt
                        [    6.458001] platform csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec80000/mvcam@3b
                          @mparem
                          Since I don't have the tablet board here, the following is just a suggested approach based on my guess. You can try commenting out the following two lines or modifying them as shown below:
                          clock-names = "xvclk";
                            I received the cm5-base board today, attempted to connect the camera, but dmesg does not show any logs when grepping for mvcam
                              @mparem https://github.com/veyeimaging/rk35xx_orangepi/releases
                              please try the latest image or deb packages.
                                @mparem
                                https://github.com/veyeimaging/rk35xx_orangepi/releases/tag/v1.2_mvcam_tablet_cm5
                                Please try this image file on cm5-tablet.
