    UNSOLVED RAW-MIPI-SC132, Orin-NX custom carrier-board
    • O
      Otca last edited by
      Hi, I have tested CSI-0 and CSI-1.
      I'm using WeAct carrierBoard (N_002) with jetson orin nx(16GB)
      I share the results with you to get to the solution faster.
      thanks in advance for your consideration.
      1. Version
      sudo ./mv_mipi_i2c.sh -r -f version -b 9
      Executing: ./mv_mipi_i2c_new.sh -r version -b 9
      version is C 01.04 and L 00.00
      2. I2C-detect:
      i2cdetect -y -r 9
           0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
      00:                         -- -- -- -- -- -- -- --
      10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      30: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
      40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      70: -- -- -- -- -- -- -- --
      3. Trigg mode
      sudo ./mv_mipi_i2c.sh -r -f trgmode -b 9
      Executing: ./mv_mipi_i2c_new.sh -r trgmode -b 9
      r trigger mode is 0
      4. v4l2-ctl
      doesnt work and I get the following messages in dmesg
       WIDTH=1080
      export HEIGHT=1280
      export FPS=50
      v4l2-ctl --set-ctrl roi_x=0
      v4l2-ctl --set-ctrl roi_y=0
      v4l2-ctl --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY
      v4l2-ctl --set-ctrl frame_rate=$FPS
      v4l2-ctl --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=-1 --stream-to=/dev/null
      5. DMESG:
      [   36.404093] mvcam 9-003b: csi2_try format
      [   36.404109] mvcam 9-003b: mvcam_csi2_get_fmt_idx_by_code success
      [   36.484983] mvcam 9-003b: csi2_try format
      [   36.484996] mvcam 9-003b: mvcam_csi2_get_fmt_idx_by_code success
      [   36.566999] mvcam 9-003b: camera_common_mclk_enable: no device power rail
      [   36.567010] mvcam 9-003b: camera_common_s_power: failed to enable mclk
      [   39.903309] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
      [   39.903335] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
      [   39.905050] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
      [   42.463311] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
      [   42.463338] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
      [   42.464861] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
      [   45.023322] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
      [   45.023351] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
      [   45.024651] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
      [   47.583304] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
      [   47.583330] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
      [   47.584733] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
      [   50.143315] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
      [   50.143348] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
      [   50.144429] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
      6. sudo dmesg | grep -i mvcam
      [   11.240305] mvcam 9-003b: veye mv series camera driver version: 01.01.06
      [   11.941759] mvcam 9-003b: camera is: RAW-MIPI-SC132M
      [   11.942058] mvcam 9-003b: firmware version: 0x1040000
      [   11.950629] tegra-camrtc-capture-vi tegra-capture-vi: subdev mvcam 9-003b bound
      [   11.982952] mvcam 10-003b: veye mv series camera driver version: 01.01.06
      [   12.686081] veye_mvcam: mvcam_read: Reading register 0x04 failed
      [   12.686095] mvcam 10-003b: failed to read chip id
      [   12.686098] mvcam 10-003b: mvcam_identify_module failed.
      7. V4l2-ctl
      v4l2-ctl --list-formats-ext
      ioctl: VIDIOC_ENUM_FMT
      	Type: Video Capture
      	[0]: 'GREY' (8-bit Greyscale)
      		Size: Discrete 1080x1280
      			Interval: Discrete 0.020s (50.000 fps)
      	[1]: 'XY10' (XAVIER 10-bit/16-bit Greyscale)
      8. Jetson Info
      jtop 4.3.2 - (c) 2024, Raffaello Bonghi [raffaello@rnext.it]
      Website: https://rnext.it/jetson_stats
       Platform                                    Serial Number: [s|XX CLICK TO READ XXX]
        Machine: aarch64                           Hardware
        System: Linux                               Model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
        Distribution: Ubuntu 22.04 Jammy Jellyfish  699-level Part Number: 699-13767-0000-300 M.1
        Release: 5.15.148-tegra                     P-Number: p3767-0000
        Python: 3.10.12                             Module: NVIDIA Jetson Orin NX (16GB ram)
                                                    SoC: tegra234
       Libraries                                    CUDA Arch BIN: 8.7
        CUDA: 12.6.68                               L4T: 36.4.3
        cuDNN: 9.3.0.75                             Jetpack: 6.2
        TensorRT: 10.3.0.30
        VPI: 3.2.4                                 Hostname: jetson
        Vulkan: 1.3.204                            Interfaces
        OpenCV: 4.8.0 with CUDA: NO                 eno1: 192.168.0.113
                                                    docker0: 172.17.0.1
      • O
        Otca last edited by
        based on https://wiki.veye.cc/index.php/RAW-MIPI-SC132M_Data_Sheet
        11 ENABLE Camera Power Enable
        The Voltage of PIN-11 is 1.74v
          veye_xumm @Otca last edited by
          @otca
          The camera is now successfully probed, which confirms that both the I2C and the enable pin are functioning correctly.
          The current issue indicates that the I2C control channel is working, but the MIPI CSI data channel is not. Please verify whether the MIPI CSI interface pin assignment on this carrier board matches that of the official Orin NX development board.
          The Device Tree Source (DTS) should be adjusted accordingly to match the carrier board.
