SOLVED Problem cross-compiling
As the raspberry folks have released a new kernel (20210430), I'm trying to compile the drivers for a new camera of @MK. Following the instructions, at the last build command I get the error:
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage modules dtbs -j2 make[2]: *** No rule to make target 'arch/arm/boot/dts/overlays/csimx307-overlay.dtbo', needed by '__build'. Stop. make[1]: *** [scripts/Makefile.build:496: arch/arm/boot/dts/overlays] Error 2What am I doing wrong? I've double checked that I did the four steps:
- add driver sources
- update Makefile and Kconfig
- add dts files
- change Makefile in dts folder
@tj said in Problem cross-compiling:
You should edit this file:
arch\arm\boot\dts\overlays\Makefileveye327.dtbo \ csimx307.dtbo \ cssc132.dtbo \ -
@veye_xumm Thanks for having a look. I had already added those lines. However I still get the error.
@tj please attach your Makefile let me take a look at it.
@veye_xumm Thanks for the offer. While posting the Makefile I noticed I had -overlay.dtbo in the filenames. Compiling now.
