    SOLVED cssc132 driver for Raspberry pi 5
      reinbb last edited by
      Hi
      Is there a cssc132 driver update coming for raspberry pi 5?
        veye_xumm @reinbb last edited by
        @reinbb cssc132.ko
        This driver has always been available and open source.
        R 2 Replies Last reply Reply Quote 0
          reinbb @veye_xumm last edited by
          @veye_xumm Thanks for the quick reply! Looks like I'm missing something. Can you help me with it?
          I followed the documentation raspberrypi_v4l2. Unsuccessfully.
          Env:
          • Raspberry Pi 5
          • OS: Linux raspberrypi 6.6.51+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt3 (2024-10-08) aarch64 GNU/Linux
          • I compiled cssc132.ko and cssc132.dtbo (from rpi-6.6.y dirs).
          • then raspberrypi_v4l2/release/driver_bin/6.6.51+rpt-rpi-2712 was created
          • after that I executed raspberrypi_v4l2/release/install_driver_rpi5.sh
          • reboot
          • then I tested /boot/firmware/config.txt:
            [all]
            dtparam=i2c_vc=on
            dtoverlay=cssc132
            dtoverlay=cssc132,cam0
          After that video0 and video1 appeared.
          Then I configured driver by executing following scripts:
          ./find_entity.sh
          Found cssc132 @ i2c-4 entity on /dev/media1
          Plese get frame from /dev/video0 and use /dev/v4l-subdev2 for camera setting.
          ./media_setting_rpi5.sh cssc132 -fmt UYVY -w 1280 -h 1080
          This is a Raspberry Pi 5.
          camera is YUV type
          camera name cssc132; width 1280; height 1080; media_fmt UYVY8_1X16; pixel_fmt UYVY
          CAM1 probed: media device is /dev/media1
          set CAM1 finish, plese get frame from /dev/video0 and use /dev/v4l-subdev2 for camera setting
          cssc132 6 NOT FOUND
          After all I tried to test cam by ffprobe /dev/video0 or /dev/video1. But I see the following errors:
          libswresample 4. 7.100 / 4. 7.100
          libpostproc 56. 6.100 / 56. 6.100
          [video4linux2,v4l2 @ 0x5555c17f7b00] ioctl(VIDIOC_G_FMT): Invalid argument
          /dev/video1: Invalid argument
            @veye_xumm Sorry. Driver works. Testing and reading should be by v4l2.
              @reinbb OK
