    NVidia Jetson Jetpack 6 support?
    15683
    • V
      vitob last edited by
      NVidia Jetson Jetpack 6.0 is now officially available. When will the camera source codes be available for JP6 then? Thanks.
        veye_xumm @vitob last edited by
        @vitob We are working on the driver port and expect it to be done and released in a week.
        • V
          vitob @veye_xumm last edited by
          @veye_xumm Thank you for replying. Expect for the new release.
            @vitob
            I've posted the drivers for Orin nano and Orin NX for Jetpack 6.0 as well as the supporting materials. Please refer to the following link.
            https://wiki.veye.cc/index.php/Nvidia_Jetson_Application_Note_Index
            O 1 Reply Last reply Reply Quote 1
            • O
              Otca @veye_xumm last edited by
              @veye_xumm Hi i have read all the wiki and downloaded https://github.com/veyeimaging/nvidia_jetson_veye_bsp
              but I am still missing dtb file for MV-MIPI-IMX264.
              I have bought 4 of them and I have tried so many times. still I cannot make use of one of those.
              I have install all the drivers and other steps i just need dtb file
              OS: ubuntu 22.04
              jeton orin nano Jetpack6.0,L4T r36.3
              please help me
              thanks
              O 1 Reply Last reply Reply Quote 0
              • O
                Otca @Otca last edited by
                @otca
                cat /etc/nv_tegra_release
                R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
                KERNEL_VARIANT: oot
                TARGET_USERSPACE_LIB_DIR=nvidia
                TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
                dmesg | grep -i 'fail'
                [ 5.067860] hid-generic: probe of 0003:1C4F:0202.0002 failed with error -22
                [ 9.577266] videodev: module verification failed: signature and/or required key missing - tainting kernel
                [ 11.795964] dce: dce_admin_setup_clients_ipc:561 Get queue info failed for [2]
                [ 12.536169] veye_mvcam: mvcam_read: Reading register 0x04 failed
                [ 12.536185] mvcam 9-0010: failed to read chip id
                [ 12.536190] mvcam 9-0010: mvcam_identify_module failed.
                [ 13.041253] veye_mvcam: mvcam_read: Reading register 0x04 failed
                [ 13.041269] mvcam 10-0010: failed to read chip id
                [ 13.041273] mvcam 10-0010: mvcam_identify_module failed.
                [ 16.965874] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
                dmesg | grep -i 'veye'
                [ 12.031976] mvcam 9-0010: veye mv series camera driver version: 01.01.04
                [ 12.539516] mvcam 10-0010: veye mv series camera driver version: 01.01.04
                dmesg | grep -i 'error'
                [ 9.363672] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
                [ 9.365895] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
                [ 9.369376] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
                  veye_xumm @Otca last edited by
                  @otca said in NVidia Jetson Jetpack 6 support?:
                  From this prompt message, it looks like your driver and dtb are doing the right thing. But now i2c probe can't get the device.
                  Please make sure your 5V dupont cable is plugged into the right place? I can't see it clearly from the picture.
                  • O
                    @veye_xumm said in NVidia Jetson Jetpack 6 support?:
                    5V dupon
                    Thnaks for fast replay
                    To double check the pin of IMX264 would u please tell me which one is 5V and which one is GND?
                    • O
                      @otca I just checked the connection and I'm sure that 5V and GND connection are OK.
                      any idea what to do?
                      • O
                        @otca let double check the DTB i must use.
                        My camera is MV-IMX264-M which one of these dtbo is the right one?
                        tegra234-camera-rbpcv3-csimx307.dtsi*
                        tegra234-camera-rbpcv3-cssc132.dtsi*
                        tegra234-camera-rbpcv3-veyecam2m.dtsi*
                        tegra234-camera-rbpcv3-veyeimx335.dtsi*
                        tegra234-camera-rbpcv3-veye_mvcam.dtsi*
                        tegra234-p3767-camera-p3768-csimx307-dual.dtbo*
                        tegra234-p3767-camera-p3768-csimx307-dual.dts*
                        tegra234-p3767-camera-p3768-cssc132-dual.dtbo*
                        tegra234-p3767-camera-p3768-cssc132-dual.dts*
                        tegra234-p3767-camera-p3768-raw_ar0234m-dual.dtbo*
                        tegra234-p3767-camera-p3768-raw_ar0234m-dual.dts*
                        tegra234-p3767-camera-p3768-raw_imx462m-dual.dtbo*
                        tegra234-p3767-camera-p3768-raw_imx462m-dual.dts*
                        tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo*
                        tegra234-p3767-camera-p3768-veyecam2m-dual.dts*
                        tegra234-p3767-camera-p3768-veyeimx335-dual.dtbo*
                        tegra234-p3767-camera-p3768-veyeimx335-dual.dts*
                        tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo*
                        tegra234-p3767-camera-p3768-veye_mvcam-dual.dts*
                            @otca
                            Please run cat /etc/extlinux/extlinux.conf, and paste here.
                            O 2 Replies Last reply Reply Quote 0
                            • O
                              TIMEOUT 50
                              DEFAULT JetsonIO
                              MENU TITLE L4T boot options
                              LABEL primary
                              MENU LABEL primary kernel
                              LINUX /boot/Image
                              INITRD /boot/initrd
                              APPEND ${cbootargs} root=PARTUUID=3354a552-d558-40fb-857c-8e1886cb2a67 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config
                              LABEL recovery
                              MENU LABEL Ubuntu (Recovery Mode - Runlevel 1)
                              LINUX /boot/Image
                              INITRD /boot/initrd
                              APPEND ${cbootargs} root=PARTUUID=3354a552-d558-40fb-857c-8e1886cb2a67 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config single
                              LABEL Multi-User-With-Networking
                              MENU LABEL Ubuntu (Multi-User-With-Networking - Runlevel 3)
                              LINUX /boot/Image
                              INITRD /boot/initrd
                              APPEND ${cbootargs} root=PARTUUID=3354a552-d558-40fb-857c-8e1886cb2a67 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config 3
                              LABEL Multi-User-With-GUI
                              MENU LABEL Ubuntu (Multi-User-With-GUI - Runlevel 5)
                              LINUX /boot/Image
                              INITRD /boot/initrd
                              APPEND ${cbootargs} root=PARTUUID=3354a552-d558-40fb-857c-8e1886cb2a67 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config 5
                              LABEL JetsonIO
                              MENU LABEL Custom Header Config: <CSI Camera IMX219 Dual>
                              LINUX /boot/Image
                              FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
                              INITRD /boot/initrd
                              OVERLAYS /boot/veyecam/tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo
                              • O
                                I have decompiled the dtb file using
                                dtc -I dtb -O dts -o decompiled.dts tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo
                                I see that these parameters are not set correctly for IMX264, correct me if I'm wrong.
                                		i2c@0 {
                                			reg = <0x00>;
                                			#address-cells = <0x01>;
                                			#size-cells = <0x00>;
                                			rbpcv3_mvcam_a@3b {
                                				compatible = "nvidia,veye_mvcam";
                                				reg = <0x3b>;
                                				devnode = "video0";
                                				physical_w = "5.6";
                                				physical_h = "3.1";
                                				sensor_model = "mvcam";
                                				use_sensor_mode_id = "false";
                                				status = "okay";
                                				reset-gpios = <0x5a 0x3e 0x00>;
                                				phandle = <0x482>;
                                				mode0 {
                                					mclk_khz = "24000";
                                					num_lanes = "2";
                                					tegra_sinterface = "serial_b";
                                					phy_mode = "DPHY";
                                					discontinuous_clk = "yes";
                                					dpcm_enable = "false";
                                					cil_settletime = "0";
                                					lane_polarity = "6";
                                					active_w = "3088";
                                					active_h = "2064";
                                					mode_type = "raw";
                                					csi_pixel_bit_depth = "8";
                                					pixel_phase = "y8";
                                					readout_orientation = "0";
                                					line_length = "3088";
                                					inherent_gain = "1";
                                					mclk_multiplier = "2";
                                					pix_clk_hz = "375000000";
                                					gain_factor = "16";
                                					framerate_factor = "1000000";
                                					exposure_factor = "1000000";
                                					min_gain_val = "16";
                                					max_gain_val = "170";
                                					step_gain_val = "1";
                                					default_gain = "16";
                                					min_hdr_ratio = "1";
                                					max_hdr_ratio = "1";
                                					min_framerate = "2000000";
                                					max_framerate = "20000000";
                                					step_framerate = "1";
                                					default_framerate = "20000000";
                                					min_exp_time = "13";
                                					max_exp_time = "333333";
                                					step_exp_time = "1";
                                					default_exp_time = "2495";
                                					embedded_metadata_height = "0";
                                The corresponding parameters for IMX264 is as follow:
                                Property IMX264
                                physical_w 8.390
                                physical_h 7.066
                                active_w 2432
                                active_h 2048
                                pixel_t RG 8,10,12
                                max_gain_val 48
                                step_gain_val 0.100
                                max_framerate (2L08) 35.5
                                max_framerate (2L10) 35.5
                                max_framerate (2L12) 35.5
                                what do u think about do the needed changes and recompile the dts to dtbo?
                                Thanks for ur help ❤
                                • O
                                  @otca i have done the top changes and still i have the same errors:
                                  [ 5.139606] hid-generic: probe of 0003:1C4F:0202.0004 failed with error -22
                                  [ 9.364966] videodev: module verification failed: signature and/or required key missing - tainting kernel
                                  [ 11.505696] dce: dce_admin_setup_clients_ipc:561 Get queue info failed for [2]
                                  [ 12.284602] veye_mvcam: mvcam_read: Reading register 0x04 failed
                                  [ 12.284613] mvcam 9-003b: failed to read chip id
                                  [ 12.284617] mvcam 9-003b: mvcam_identify_module failed.
                                  [ 12.795113] veye_mvcam: mvcam_read: Reading register 0x04 failed
                                  [ 12.795129] mvcam 10-003b: failed to read chip id
                                  [ 12.795133] mvcam 10-003b: mvcam_identify_module failed.
                                  [ 17.325445] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
                                  dmesg | grep -i 'i2c'
                                  [ 0.236421] i2c_dev: i2c /dev entries driver
                                  [ 3.375822] tegra-i2c 3160000.i2c: Adding to iommu group 1
                                  [ 3.380887] tegra-i2c 3180000.i2c: Adding to iommu group 1
                                  [ 3.384775] tegra-i2c 31b0000.i2c: Adding to iommu group 1
                                  [ 3.388075] tegra-i2c c240000.i2c: Adding to iommu group 1
                                  [ 3.391424] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
                                  [ 3.392065] tegra-i2c c250000.i2c: Adding to iommu group 1
                                  [ 3.396084] i2c i2c-2: Added multiplexed i2c bus 9
                                  [ 3.396781] i2c i2c-2: Added multiplexed i2c bus 10
                                  [ 3.396786] i2c-mux-gpio bus@0:cam_i2cmux: 2 port mux on 3180000.i2c adapter
                                  [ 11.782990] mvcam 9-003b: veye mv series camera driver version: 01.01.04
                                  [ 12.286011] mvcam 10-003b: veye mv series camera driver version: 01.01.04
                                    @otca
                                    I would say that this phenomenon now has nothing to do with the details of the dts. The problem now is that i2c doesn't work.
                                    This is often something to do with the hardware connection cables, and whether the camera is working properly.
                                    Do you have a multimeter? An oscilloscope? Can you measure the power supply to the camera module, and whether the i2c communication is working?
                                      @otca
                                      Have you ever disassembled the camera module?Is the direction of the internal FFC flex cable correct?
                                      • O
                                        I have not disassembled camera but if you think i should disassemble and check connections, I'll give it a try.
                                        if its possible please give me reference needed for this part.
                                        and for the other question, I did check the power supply and it was 5.14 V.
                                        • O
                                            @otca
                                            There's nothing wrong with that in my opinion. You have 4 cameras, have you tried any others?
                                            Or try plugging the camera into another mipi port ?
