    SOLVED RAW-MIPI-SC132M驱动编译后无法正常播放
    2879
    • A
      ashengzi last edited by
      按照官方手册移植RAM-MIPI-SC132M驱动到rk35xx_radxa驱动radxa 3w,程序启动正常:
      抓帧也正常:
      但是用v4l2dev_2_opencv_show_grey.py运行时会卡死,无图像输出。
      单独运行gst-launch-1.0 v4l2src io-mode=dmabuf device=/dev/video0 ! video/x-raw, format=GRAY8, width=1024, height=1280 ! videoconvert ! autovideosink命令时也会卡死在2s左右。请问下这个是什么原因造成的,如何去排查?
      • A
        8f9c1cbf-f04f-4ee2-b525-3c96ae3a0f83-image.png 报了这个错误
          veye_xumm @ashengzi last edited by
          @ashengzi
          你调用
          python3 ./v4l2dev_2_opencv_show_grey.py --width 1024--height 1280--fps 60 --i2c 2
          试一下
          A 1 Reply Last reply Reply Quote 0
          • A
            • A
              ashengzi @veye_xumm last edited by
              @veye_xumm said in RAW-MIPI-SC132M驱动编译后无法正常播放:
              @ashengzi
              你调用
              试一下
              试过了,也不行
                @ashengzi 比较奇怪,按理说v4l2-ctl取图成功,用python预览也就可以成功的。因为其底层都是v4l2驱动接口。
                • A
                  v4l2-ctl -D --verbose -d /dev/video0 --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-${WIDTH}x${HEIGHT}.raw
                  VIDIOC_QUERYCAP: ok
                  Driver Info:
                  Driver name : rkcif
                  Card type : rkcif
                  Bus info : platform:rkcif_mipi_lvds
                  Driver version : 5.10.160
                  Capabilities : 0x84201000
                  Video Capture Multiplanar
                  Streaming
                  Extended Pix Format
                  Device Capabilities
                  Device Caps : 0x04201000
                  Streaming
                  Extended Pix Format
                  Media Driver Info:
                  Driver name : rkcif
                  Model : rkcif_mipi_lvds
                  Serial :
                  Bus info :
                  Media version : 5.10.160
                  Hardware revision: 0x00000000 (0)
                  Interface Info:
                  Type : V4L Video
                  Entity Info:
                  Function : V4L2 I/O
                  Pad 0x01000004 : 0: Sink
                  Link 0x0200002f: from remote pad 0x1000022 of entity 'rockchip-mipi-csi2': Data, Enabled
                  Link 0x0200003d: from remote pad 0x1000023 of entity 'rockchip-mipi-csi2': Data
                  Link 0x0200004b: from remote pad 0x1000024 of entity 'rockchip-mipi-csi2': Data
                  Link 0x02000059: from remote pad 0x1000025 of entity 'rockchip-mipi-csi2': Data
                  VIDIOC_G_FMT: ok
                  VIDIOC_S_FMT: ok
                  Format Video Capture Multiplanar:
                  Width/Height : 1024/1280
                  Pixel Format : 'GREY' (8-bit Greyscale)
                  Field : None
                  Number of planes : 1
                  Flags :
                  Colorspace : Default
                  Transfer Function : Default
                  YCbCr/HSV Encoding: Default
                  Quantization : Default
                  Plane 0 :
                  Bytes per Line : 1024
                  Size Image : 1310720
                  VIDIOC_REQBUFS returned 0 (Success)
                  VIDIOC_QUERYBUF returned 0 (Success)
                  VIDIOC_QBUF returned 0 (Success)
                  VIDIOC_STREAMON returned 0 (Success)
                  cap dqbuf: 0 seq: 0 bytesused: 1310720 ts: 1211.810033 delta: 1211810.033 ms (ts-monotonic, ts-src-eof)
                  gstreamer版本没有问题,单张抓图也没有问题,抓帧也没问题,搞不明白问题出在哪里了?
                  • A
                    ashengzi @ashengzi last edited by
                    @ashengzi said in RAW-MIPI-SC132M驱动编译后无法正常播放:
                    VIDIOC_QUERYCAP: ok
                    Driver Info:
                    Driver name : rkcif
                    Card type : rkcif
                    Streaming
                    Extended Pix Format
                    Device Capabilities
                    Streaming
                    Extended Pix Format
                    Media Driver Info:
                    Driver name : rkcif
                    Serial :
                    Bus info :
                    Interface Info:
                    Type : V4L Video
                    Entity Info:
                    Function : V4L2 I/O
                    VIDIOC_G_FMT: ok
                    VIDIOC_S_FMT: ok
                    Field : None
                    Flags :
                    Plane 0 :
                    我这边发现我编译的radxa官方固件是5.10.160-1,而veye官网上用的是Linux radxa-zero3 5.10.160-26,这个有影响吗
                      这个没有关系。
                      我这边测试了一下没问题啊。
                      另外提一下,我这边OS用的是radxa发布的debain系统,不是ubuntu系统。 不知你这用的什么系统?
                      A 2 Replies Last reply Reply Quote 0
                      • A
                        这个没有关系。
                        我这边测试了一下没问题啊。
                        我这个也是deban系统,驱动运行正应该是正常的,但就是无法正常播放,好像卡在哪个地方了
                        • A
                          系统启动时好像有报错,不知道和这个是否有关?
                            客户已解决。是kernel配置中关于rkcif的配置原因。
