    RK3568 GC8034 相机预览画面异常绿屏
    Rockchip App camera
      Scroll last edited by
      描述
      我这边用的是2 lane配置,dts文件如下
      S J 2 Replies Last reply Reply Quote 0
        Scroll @Scroll last edited by
         EVB3568 V2 csi split mode
                vcc_camera: vcc-camera-regulator {
                        compatible = "regulator-fixed";
                        gpio = <&gpio0 RK_PD3 GPIO_ACTIVE_HIGH>;
                        pinctrl-names = "default";
                        pinctrl-0 = <&camera_pwr>;
                        regulator-name = "vcc_camera";
                        enable-active-high;
                        regulator-always-on;
                        regulator-boot-on;
                flash_sgm3141:flash-sgm3141 {
                        status = "okay";
                        compatible = "sgmicro,sgm3141";
                        label = "gpio-flash";
                        pinctrl-0 = <&flash_led_gpios>;
                        led-max-microamp = <20000>;
                        flash-max-microamp = <20000>;
                        flash-max-timeout-us = <1000000>;
                        strobe-gpios = <&gpio3 RK_PD4 GPIO_ACTIVE_HIGH>;
                        enable-gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_HIGH>;
        &i2c4 {
        	status = "okay";
                dw9714: dw9714@0c {
        		compatible = "dongwoon,dw9714";
        		status = "okay";
        		reg = <0x0c>;
        		rockchip,vcm-max-current = <100>;
        		rockchip,vcm-start-current = <0>;
        		rockchip,vcm-rated-current = <100>;
        		rockchip,vcm-step-mode = <0xd>;
        		rockchip,vcm-dlc-enable = <0>;
        		rockchip,vcm-mclk = <0>;
        		rockchip,vcm-t-src = <0>;
        		rockchip,camera-module-facing = "back"; //"fornt";
                gc8034: gc8034@37 {
        		status = "okay";
        		compatible = "galaxycore,gc8034";
        		reg = <0x37>;
                        clocks = <&cru CLK_CAM0_OUT>;
                        clock-names = "xvclk";
                        power-domains = <&power RK3568_PD_VI>;
                        pinctrl-0 = <&cam_clkout0>;
        		//pinctrl-1 = <&cam_split_2>;
        		// power-gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>;
        		// reset-gpios = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>;
        		// pwdn-gpios = <&gpio3 RK_PD7 GPIO_ACTIVE_HIGH>;
                        reset-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_LOW>;
                        pwdn-gpios = <&gpio4 RK_PA1 GPIO_ACTIVE_LOW>;
                        rockchip,grf = <&grf>;
                        rockchip,camera-module-name = "RK-CMK-8M-2-v1";
                        rockchip,camera-module-lens-name = "CK8401";
                        lens-focus = <&dw9714>;
                        flash-leds = <&flash_sgm3141>;
        		port {
        			gc8034_2_out: endpoint {
        				remote-endpoint = <&dphy1_in>;
        				data-lanes = <1 2>;
                ov8858: ov8858@36 {
                        status = "disabled";
                        compatible = "ovti,ov8858";
                        reg = <0x36>;                     //36,10
                        //pinctrl-1 = <&cam_split_1>;
                        reset-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_HIGH>;
                        pwdn-gpios = <&gpio4 RK_PA1 GPIO_ACTIVE_HIGH>;
                        rockchip,camera-module-index = <1>;
                        rockchip,camera-module-facing = "front";
                        rockchip,camera-module-name = "HS5885-BNSM1018-V01";
                        rockchip,camera-module-lens-name = "default";
                        port {
                                ov8858_out: endpoint {
                                        remote-endpoint = <&dphy1_in_ov8858>;
                                        data-lanes = <1 2>;
        &i2c2 {
                status = "okay";
                pinctrl-0 = <&i2c2m1_xfer>;
                dw9714: dw9714@0c {
        		status = "okay";
        		reg = <0x0c>;
                gc8034: gc8034@37 {
        		status = "okay";
        		reg = <0x37>;
                        clocks = <&cru CLK_CAM1_OUT>;
                        pinctrl-0 = <&cam_clkout1>;
        		reset-gpios = <&gpio3 RK_PD6 GPIO_ACTIVE_LOW>;
        		pwdn-gpios = <&gpio3 RK_PD7 GPIO_ACTIVE_LOW>;
        		port {
        				remote-endpoint = <&dphy2_in>;
        				data-lanes = <1 2>;
        &csi2_dphy0 {
        &csi2_dphy1 {
                status = "okay";
                * dphy1 only used for split mode,
                * can be used  concurrently  with dphy2
                * full mode and split mode are mutually exclusive
                ports {
                        #address-cells = <1>;
                        #size-cells = <0>;
                        port@0 {
                                reg = <0>;
                                #size-cells = <0>;
                                dphy1_in_ov8858: endpoint@1 {
                                                reg = <1>;
                                                remote-endpoint = <&ov8858_out>;
                                                data-lanes = <1 2>;
                        port@1 {
                                reg = <1>;
                                #size-cells = <0>;
                                dphy1_out: endpoint@1 {
                                                reg = <1>;
                                                remote-endpoint = <&isp0_in>;
        &csi2_dphy2 {
                status = "okay";
                * dphy2 only used for split mode,
                * can be used  concurrently  with dphy1
                ports {
                        #size-cells = <0>;
                        port@0 {
                                reg = <0>;
                                #size-cells = <0>;
                                dphy2_in: endpoint@1 {
                                                reg = <1>;
                                                remote-endpoint = <&gc8034_2_out>;
                                                data-lanes = <1 2>;
                        port@1 {
                                reg = <1>;
                                #size-cells = <0>;
                                dphy2_out: endpoint@1 {
                                                reg = <1>;
                                                remote-endpoint = <&mipi_csi2_input>;
        &mipi_csi2 {
                status = "okay";
                ports {
                        #size-cells = <0>;
                        port@0 {
                                reg = <0>;
                                #size-cells = <0>;
                                mipi_csi2_input: endpoint@1 {
                                                reg = <1>;
                                                remote-endpoint = <&dphy2_out>;
                                                data-lanes = <1 2>;
                        port@1 {
                                reg = <1>;
                                #size-cells = <0>;
                                mipi_csi2_output: endpoint@0 {
                                                reg = <0>;
                                                remote-endpoint = <&cif_mipi_in>;
                                                data-lanes = <1 2>;
        &rkcif_mipi_lvds {
                status = "okay";
                port {
                        cif_mipi_in: endpoint {
                                remote-endpoint = <&mipi_csi2_output>;
                                data-lanes = <1 2>;
        &rkcif_mipi_lvds_sditf {
                status = "okay";
                port {
                        mipi_lvds_sditf: endpoint {
                                remote-endpoint = <&isp1_in>;
                                data-lanes = <1 2>;
        &csi2_dphy_hw {
        	status = "okay";
        &rkisp {
        	status = "okay";
        &rkisp_mmu {
        	status = "okay";
        &rkisp_vir0 {
                status = "okay";
                port {
                        #size-cells = <0>;
                        isp0_in: endpoint@0 {
                                reg = <0>;
                                remote-endpoint = <&dphy1_out>;
        &rkisp_vir1 {
                status = "okay";
                port {
                        #size-cells = <0>;
                        isp1_in: endpoint@0 {
                                reg = <0>;
                                remote-endpoint = <&mipi_lvds_sditf>;
        &rkcif_mmu {
            status = "okay";
        &rkcif {
            status = "okay";
        &pinctrl {
                cam {
                        camera_pwr: camera-pwr {
                                rockchip,pins =
                                        /* camera power en */
                                        <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
        	camera_pins {
        		cam_split_1: cam_split-1 {
        			rockchip,pins = <4 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>,
                                                <4 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
                        cam_split_2: cam_split-2 {
        			rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>,
                                                <3 RK_PD7 RK_FUNC_GPIO &pcfg_pull_up>;
                flash-led {
                        flash_led_gpios: flash-led {
                                rockchip,pins =
                                        /* flash led enable*/
                                        <3 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>,
                                        <3 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>;
          veye_xumm @Scroll last edited by
          @scroll 你好,gc8034不是我们的产品。
            jzz @Scroll last edited by
            @scroll 您好,我使用其他的相机,遇到了和您一样的问题,请问您解决了吗?
