    SOLVED imx462 driver update for raspberrypi 6.1.21-v8+
    • Z
      zoldaten last edited by zoldaten
      hello.
      i am trying install driver on raspbian bullseye:
      6.1.21-v8+
      following the steps -
      https://wiki.veye.cc/index.php/Build_drivers_from_source_for_rpi
      i did:
      sudo apt update
      sudo apt full-upgrade
      sudo apt install raspberrypi-kernel-headers
      cd ~/rasp/driver_source/cam_drv_src/rpi-6.1.y
      make
      after that :
      cd raspberrypi_v4l2/release/
      sudo ./install_driver.sh veyecam2m
      reboot
      but camera doesnt work:
      dmesg | grep veye
      [    0.068867] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/veyecam2m@3b
      [   10.519453] veyecam2m: loading out-of-tree module taints kernel.
      [   10.645721] veyecam2m 10-003b: probe failed
      what should be done in addition ?
      ok, fixed that - i use cm4 so need to add to /boot/config.txt:
      dtoverlay=veyecam2m
      dtoverlay=veyecam2m,cam0
        veye_xumm @zoldaten last edited by
        @zoldaten Approve
