    SOLVED IMX462 and Jetson Nano problem
      joe last edited by
      I'm trying to use the IMX462 v-eye camera with a Jetson Nano. My Jetpack version is 4.6. I followed the instructions on this link:
      https://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2
      After copying the "tegra210-p3448-0000-p3449-0000-b00.dtb" file to "/boot/veyecam" and making changes to the "/boot/extlinux/extlinux.conf" file, I restarted the board. However, I encountered the following error:
      dmesg | grep veye
      [ 2.436857] veyecam 7-003b: probing v4l2 sensor
      [ 2.437085] veyecam 7-003b: tegracam sensor driver: veyecam_v2.0.6
      [ 3.544132] veyecam 7-003b: probe failed
      [ 3.548192] veyecam 7-003b: board setup failed
      [ 3.552794] veyecam 8-003b: probing v4l2 sensor
      [ 3.553005] veyecam 8-003b: tegracam sensor driver: veyecam_v2.0.6
      [ 3.563049] veyecam 8-003b: probe failed
      [ 3.567120] veyecam 8-003b: board setup failed
      What should I check next?
      Thank you for your support.
      Best regards,
      Joe
        veye_xumm @joe last edited by
        @joe The software part of the work seems fine. Next, we need to check if the hardware connections are correct, paying particular attention to the orientation of the FFC cable.
