    SOLVED IMX335 trigger synchronization
    • H
      hchorsi last edited by
      Can the IMX335 sensor be synchronized with an illumination source such as projector using trigger pins? What are the requirements for the trigger signal in terms of the frequency, amplitude, duty cycle,...?
      Thank you
        veye_xumm @hchorsi last edited by
        @hchorsi said in IMX335 trigger synchronization:
        Sorry, the VEYE-MIPI-IMX335 has an ISP module and does not support external synchronization and trigger signals.
