    SOLVED Can I use YT1.8-2.1I lens with RAW-MIPI-AR0234M?
      Roman last edited by
      Hello, I just ordered AGX-nCAM-AR0234M kit. I already have YT1.8-2.1I lens, will they fit?
        veye_xumm @Roman last edited by
        @roman said in Can I use YT1.8-2.1I lens with RAW-MIPI-AR0234M?:
        YT1.8-2.1I
        YT1.8-2.1I has an IRCUT switch, so it has the control pins for IRCUT. However, the AR0234M does not have this interface. This means they are not a perfect match.
        However, in terms of lens parameters, it is indeed applicable.
          Roman @veye_xumm last edited by
          @veye_xumm Thanks, this should be enough I think
