    SOLVED IMX462 with Raspberry Pi Zero 2
      Nathan Sinclair last edited by
      Followed instructions in 327 instructions for raspberrypi
      1. enabled legacy mode in bullseye raspi
      2. ran ./veye_raspipreview -v -t -1 -p '0,0,1920,1080'
      3. ran ./veye_raspistill -o ./test.jpg
      here's the verbose output for the 2 commands
      before create camera com time out -1
      veye_raspipreview Camera App v0.3.7
      Width 1920, Height 1080, filename (null)
      Time delay -1, Timelapse 0
      Link to latest frame enabled  no
      Full resolution preview No
      Capture method : Single capture
      Preview Yes, Full screen No
      Preview window 0,0,1920,1080
      Opacity 255
      Hardare version: 902120
      mmal: mmal_component_enable w 1920 h 1080 fps 30
       raspipreview_create  com
      before create camera com sensor mode 0
      Neither program produces any output. Confirmed that the camera is plugged correctly into the camera port.
        veye_xumm @Nathan Sinclair last edited by
        @nathan-sinclair
        Please refer to the following link.
        https://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/
        Before any operation, please execute the command provided.
        ./camera_i2c_config
          Nathan Sinclair @veye_xumm last edited by
          @veye_xumm It reports i2c information, sensor is imx462, but i still couldn't get a preview of the camera.
            @nathan-sinclair
            Is this the board you're using? I'll try it.
            https://www.raspberrypi.com/products/raspberry-pi-zero-2-w/
              The feedback from this link below is the same as your problem, and although it is in Chinese, the images in it are informative.
              https://forum.veye.cc/topic/187/veye-mipi-imx385在新版raspberry-pi-zero-2-w上无法使用
              I'll list the points to use:
              1. Use a separate 5V supply.
              2. On the raspberry pi zero 2w, the power on enable pin for camera, needs to be executed separately:
               raspi-gpio set 40 dh
              Once this is done, the camera can be detected on the i2c-10 bus.
               i2cdetect -y 10
              The 0x3b device can be detected and the script can read and write camera parameters now.
              After completing the above steps, you can use the veye_raspicam series software normally.
