    SOLVED CS-LAMP-IR Frame Synchronization
      nimble99 last edited by
      I am looking for a night vision sensor with IR board, and came across this product.
      One of my requirements is for energy efficiency - so illuminating the subject only when the sensor is capturing a frame helps with this.
      When in "night mode", does the lamp module synchronize it's pulses of IR light to the frame-sync of the sensor - or is the IR lamp running a full duty cycle?
      Thank you!
        veye_xumm @nimble99 last edited by
        @nimble99 Hi, this board won't work for you. It's a IR lamp running a full duty cycle.
