SOLVED IMX287M on CM4 Bullseye 11 Linux 6.1.21
Hi, I'm trying to run the IMX287M camera on a Compute Module 4 running Bullseye 11 and Linux 6.1.21v8+.
I'm following the instructions in the Wiki:
https://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_rpiI enabled I2C on the CM4, connected the power DuPont cables and installed the driver, but when running
dmesg | grep mvcamI get the error
pi@raspberrypi:~ $ dmesg | grep mvcam [ 0.071124] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/veyemvcam@3b [ 8.791147] veye_mvcam: loading out-of-tree module taints kernel. [ 8.800226] mvcam 10-003b: veye mv series camera driver version: 01.01.04 [ 8.806688] mvcam 10-003b: Unable to load veye_vbyone driver,will go on [ 9.310786] mvcam: mvcam_read: Reading register 0x04 failed [ 9.310817] mvcam 10-003b: failed to read chip idAnd I get no device on
/dev/video0(so I can't use thev4l2-ctlcommands).
@etale_cohomology
I think the FFC cable direction is wrong here.
