    Error installing driver V4L2 on raspberry pi
      MK last edited by
      Good day,
      during install on Raspberry pi 4 8GB I get the following error:
      pi@raspberrypi:~/raspberrypi_v4l2/release $ sudo ./install_driver.sh csimx307
      usage: sudo ./install_driver.sh veye327/csimx307/cssc132
      Enable i2c0 adapter...
      Add dtoverlay=csimx307 to /boot/config.txt
      Add gpu=400M to /boot/config.txt
      Add cma=128M to /boot/cmdline.txt
      Installing the csimx307.ko driver
      install: cannot stat './driver_bin/5.10.17-v7l+/csimx307.ko': No such file or directory
      install: cannot stat './driver_bin/5.10.17-v7l+/csimx307.dtbo': No such file or directory
      Any Idea how to solve?
        veye_xumm @MK last edited by
        @mk
        There are really too many kernel versions of raspberry pie. We have not provided the compiled ko file for your version of kernel, could you please compile it according to the code?
        T 1 Reply Last reply Reply Quote 0
        • T
          tj @veye_xumm last edited by
          I'm trying to do this (compiling now). I found the wiki a bit hard to follow. In step 8.6 (Add compilation options), it says 'the path is driver --> multimedia --> i2C', however for me it was 'Device Drivers --> Multimedia Support --> Media ancillary drivers --> Camera sensor devices --> '
          • T
            tj @tj last edited by
            I created a pull request with the new drivers: https://github.com/veyeimaging/raspberrypi_v4l2/pull/6
              veye_xumm @tj last edited by
              @tj Thank you very much, I will merge you commit.
                MK @veye_xumm last edited by
                Problem solved, this topic can be closed.
                Thx!
