    SOLVED Taking images with different shutter settings i2c
      Seka last edited by
      Hi there,
      I am trying to use the Starvis 327 RPI Mipi Camera with an RPI4B to take images with different illumination settings. For our use case, I need to change the shutter settings to adjust for different levels of light.
      I tried to enable the "capture mode" in order to change the shutter settings but always get a kernel error when trying to do so.
      Here is the script:
      from time import sleep
      from signal import pause
      import datetime
      import time
      import RPi.GPIO as GPIO
      import D_mipicamera as Dcam
      import os
      status = os.system('sh ./veye_mipi_i2c.sh -w -f videoformat -p1 PAL  -b 10')
      status = os.system('sh ./veye_mipi_i2c.sh -w -f cameramode -p1 0x1 -b 10')
      print status
      camera = Dcam.mipi_camera()
      camera.init_camera()
      #Folder CREATION
      #os.makedirs("/home/pi/testmipi")
      directory="/home/pi/testmipi/"
      directory
      sleep(2)
      date = datetime.datetime.now().strftime("%m_%d_%Y_%H_%M_%S")
      frame = camera.capture(encoding = 'jpeg')
      frame.as_array.tofile((directory)+"nm385"+ date + ".jpg")
      camera.release_buffer(frame)
      del frame
      time.sleep(1)
      print("Close camera...")
      camera.close_camera()
      GPIO.cleanup(Alled)
      The error I get is:
      An error ocurred while starting the kernel
      mmal: mmal_component_enable w 1920 h 1080
      It works in stream mode, but node in capture mode...
      But in stream mode it seams like i cannot change the shutter speed.
        Seka @veye_xumm last edited by
        @veye_xumm OK, so accordin to your suggestion,
        I now switched back to stream mode and discard one frame taken with the capture command before taking another one and saving it:
        import os
        status = os.system('sh ./veye_mipi_i2c.sh -w -f cameramode -p1 0x0 -b 10')
        print status
        status = os.system('sh ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFC -p1 0x00 -b 10')
        #print status
        ##turn off automatic exposure
        status = os.system('sh ./veye_mipi_i2c.sh -w -f agc -p1 0 -b 10')
        print status
        ##turn off white balance
        status = os.system('sh ./veye_mipi_i2c.sh -w -f wbmode -p1 0x1b -b 10')
        print status
        status = os.system('sh ./veye_mipi_i2c.sh -w -f lowlight -p1 0x09  -b 10')
        print status
        del frame
        time.sleep(1)
        frame.as_array.tofile((directory)+"nm590"+ date + ".jpg")
        del frame
        Now it is taking repeatedly and reliably the same images. That is good.
        However, I feel like I am not in control of the shutter/ frame rate. I tried different framerate settings with *lowlight -p1 XX but nothing changed.
        How can I change the exposure time now?
          Seka @Seka last edited by
          These are the 2c settings:
          I2C Settings
          Devid: 0x6
          Hdver: 0x3
          Wdrmode: 0x0
          Videomode: frame rate reg 1, NTSC (60Hz)
          Mirrormode: 0x0
          Denoise: 0x5
          AGC: 0x c
          Lowlight: 0x 0
          Daynightmode: 0xfc
          Mshutter: 0x41
          Cameramode: 0x0
          Nodf: 0x0
          CAPTURE  ????
          Csienable 0x1
          Brightness: NTSC60 brightness is 0x20
          Agcspeed: agcspeed is 0x a shutter speed is 0x50
          Contrast: 0x80
          Saturation: 0x28
          Sharpen : enable is 0x1 cal is 0x3
          Wdrtargetbr: 0x30
          Boardmodel: no information
          I2cwen: no information
          I2cauxenable: no information
            veye_xumm @Seka last edited by
            @seka
            1. about capture mode:
            • http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#cameramode
              Caputre mode: output the next frame each capture cmd.
              You have to run the cmd below to get one picture.
            ./veye_mipi_i2c.sh -w -f capture -b 10
            • camera.capture(encoding = 'jpeg')
              This function do CAPTURE one frame from the MIPI csi-2 port.
            1. So I suggest add this cmd before capture a frame.
              @veye_xumm and then change the shutter with mshutter or with lowlight command?
              S veye_xumm 2 Replies Last reply Reply Quote 0
                @seka Sometimes I have the impression that the frame I get in the images is an old one. Can there be a problem with having "old" frames in the images?
                  @seka
                  mshutter is manual exposure time.
                    @seka said in Taking images with different shutter settings i2c:
                    Could you add a little sleep between mshutter cmd and capture cmd?
                      import os
                      print status
                      #print status
                      print status
                      print status
                      print status
                      del frame
                      time.sleep(1)
                      del frame
                        @seka Sorry, my bad, I can change the exposure now with the mshutter command.
                        THANK YOU for your help!
                          @seka
                          It's really nice to know this. You are welcome.
