    SOLVED Please update the V4L2 Driver for 5.15.84-v7l+
      DawidC last edited by
      Hi, could you update the Raspberry Pi 4, V4L2 Driver for kernel version 5.15.84-v7l+, please?
      Best Regards, Dawid C.
        I am also trying to compile and install the drivers on my raspberry pi locally but what are the steps after? Done this so far:
        Prepare environment
        sudo apt install git bc bison flex libssl-dev make
        Download the kernel headers for the local piOS
        sudo apt install raspberrypi-kernel-headers
        Download drivers code from veye
        git clone https://github.com/veyeimaging/raspberrypi_v4l2.git
        Confirm the version of piOS on your own Raspberry Pi
        $ uname -a
        Linux camkeller 5.15.84-v7l+ #1613 SMP Thu Jan 5 12:01:26 GMT 2023 armv7l GNU/Linux
        Compile drivers
        cd ~/raspberrypi_v4l2/driver_source/cam_drv_src/rpi-5.15_all
        make
        Compile dts
        cd ~/raspberrypi_v4l2/driver_source/dts/rpi-5.15.y
        ./build_dtbo.sh
        Now how to install this?
          veye_xumm @DawidC last edited by
          @dawidc You've done most of the work beautifully.
          For the released version, we provide a . /install_driver.sh script to complete the driver installation. Refer to http://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi part4.2
          What should you do next?
          1. Create a 5.15.84-v7l+ directory in this directory raspberrypi_v4l2/release/driver_bin.
          2. Copy the ko and dtbo files you compiled to this directory.
          3. sudo ./install_driver.sh [camera module]
            DawidC @veye_xumm last edited by
            Thank you, it worked 🙂
