    UNSOLVED Read MV-MIPI-SC130M with openCV
      skyhorizon last edited by
      我尝试使用三个v4l2_opencv_show.py示例读取相机视频流,然而均无法打开摄像头,使用的是cv2.vedioCapture()方法:
      cap = cv2.VideoCapture("v4l2src io-mode=dmabuf device=/dev/video0 ! video/x-raw, format=(string)GREY, width=(int)1280, height=(int)1024 ! appsink")
      SC130M支持GREY、Y10等格式,但V4L2的x-raw并不支持,我尝试使用cv2.vedioCapture(0)、缺省format参数,x-raw支持的format=GRAY8进行读取,但是结果显示
      [ WARN:0] global ../modules/videoio/src/cap_gstreamer.cpp (1824) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module v4l2src0 reported: Device '/dev/video0' does not support 1:4:7:1 colorimetry
      我也尝试使用相机支持的GREY进行读取,但是gstreamer无法识别:
      [ WARN:0] global ../modules/videoio/src/cap_gstreamer.cpp (734) open OpenCV | GStreamer warning: Error opening bin: could not link v4l2src0 to appsink0, v4l2src0 can't handle caps video/x-raw, format=(string)GREY, width=(int)1280, height=(int)1024
      [ WARN:0] global ../modules/videoio/src/cap_gstreamer.cpp (501) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
      camera open failed
        veye_xumm @skyhorizon last edited by
        @skyhorizon 你使用的主板是什么? 运行环境是什么版本?
          skyhorizon @veye_xumm last edited by
          RPI OS 5.15.84 驱动是本地编译的5.15_all。
          v4l2-ctl -d /dev/video0 --all
          Driver Info:
          	Driver name      : unicam
          	Card type        : unicam
          	Bus info         : platform:fe801000.csi
          	Driver version   : 5.15.84
          	Capabilities     : 0x85a00001
          		Video Capture
          		Metadata Capture
          		Read/Write
          		Streaming
          		Extended Pix Format
          		Device Capabilities
          	Device Caps      : 0x05200001
          		Video Capture
          		Read/Write
          		Streaming
          		Extended Pix Format
          Media Driver Info:
          	Model            : unicam
          	Serial           :
          	Media version    : 5.15.84
          	Hardware revision: 0x00000000 (0)
          Interface Info:
          	Type             : V4L Video
          Entity Info:
          	Function         : V4L2 I/O
          	Flags         : default
          	Pad 0x01000004   : 0: Sink
          	  Link 0x02000007: from remote pad 0x1000002 of entity 'mvcam 10-003b': Data, Enabled, Immutable
          Priority: 2
          Video input : 0 (Camera 0: ok)
          Format Video Capture:
          	Width/Height      : 1280/1024
          	Pixel Format      : 'GREY' (8-bit Greyscale)
          	Field             : None
          	Bytes per Line    : 1280
          	Size Image        : 1310720
          	Colorspace        : sRGB
          	Transfer Function : Default (maps to sRGB)
          	YCbCr/HSV Encoding: Default (maps to ITU-R 601)
          	Quantization      : Default (maps to Full Range)
          	Flags             :
          Crop Capability Video Capture:
          	Bounds      : Left 0, Top 0, Width 1280, Height 1024
          	Default     : Left 0, Top 0, Width 1280, Height 1024
          	Pixel Aspect: 1/1
          Selection Video Capture: crop, Left 0, Top 0, Width 1280, Height 1024, Flags:
          Selection Video Capture: crop_default, Left 0, Top 0, Width 1280, Height 1024, Flags:
          Selection Video Capture: crop_bounds, Left 0, Top 0, Width 1280, Height 1024, Flags:
          Selection Video Capture: native_size, Left 0, Top 0, Width 1280, Height 1024, Flags:
          User Controls
                          horizontal_flip 0x00980914 (bool)   : default=0 value=0
                            vertical_flip 0x00980915 (bool)   : default=0 value=0
                             trigger_mode 0x00981901 (int)    : min=0 max=2 step=1 default=0 value=0 flags=volatile, execute-on-write
                              trigger_src 0x00981902 (int)    : min=0 max=1 step=1 default=1 value=1 flags=volatile, execute-on-write
                              soft_trgone 0x00981903 (button) : flags=write-only, execute-on-write
                               frame_rate 0x00981904 (int)    : min=0 max=22 step=1 default=22 value=22 flags=volatile, execute-on-write
          Camera Controls
                   camera_sensor_rotation 0x009a0923 (int)    : min=0 max=0 step=1 default=0 value=0 flags=read-only
          Image Processing Controls
                               pixel_rate 0x009f0902 (int64)  : min=750000000 max=750000000 step=1 default=750000000 value=750000000 flags=read-only
          ~ $ dmesg | grep mvcam
          [    8.132715] veye_mvcam: loading out-of-tree module taints kernel.
          [    8.648215] mvcam 10-003b: camera is: MV-MIPI-SC130M
          [    8.649037] mvcam 10-003b: firmware version: 0x1260132
          [    8.657495] mvcam 10-003b: Consider updating driver mvcam to match on endpoints
            skyhorizon @skyhorizon last edited by
            @skyhorizon 硬件平台是RPI 4B
              @skyhorizon
              请参考以下这个回复
              http://forum.veye.cc/topic/304/求助树莓派mv-mipi-imx178m-使用python调用cv2-videocapture显示can-t-open-camera-by-index/2
                @veye_xumm 能否提供一些在python或是c/c++中可用的读取接口或程序示例,我需要一个确定可用的程序对摄像头进行功能测试,最好能兼容opencv和gstreamer
