    SOLVED Seldom artefacts with veye-mipi-imx462
    892
      milank last edited by
      I am testing the camera for astronomical application.
      The gstreamer pipeline is:
      v4l2src io-mode=dmabuf device=/dev/video0 ! video/x-raw,format=UYVY,width=1920,height=1080,framerate=25/1 ! v4l2convert capture-io-mode=dmabuf output-io-mode=dmabuf ! videoscale ! video/x-raw,width=1280,height=720 ! appsink sync=1
      Ocassionaly, I get artefacts like the picture below. Any idea how to get rid of this?
      alt text
      (the green bar in the middle)
      Milan
        veye_xumm @milank last edited by
        @milank
        Are you using it on a Raspberry Pi? Can you tell me about the software and hardware configuration of your board?
          milank @veye_xumm last edited by
          Yes, it is Pi4 4GB RAM
          $ uname -a
          Linux raspberrypi 5.15.32-v7l+ #1537 SMP Wed Mar 30 17:15:45 BST 2022 armv7l GNU/Linux
          $ ./veye_mipi_i2c.sh -r -f hdver
          hardware version is 0x 5
          release date is 2020- 8-14
          $ modinfo veyecam2m
          filename: /lib/modules/5.15.32-v7l+/kernel/drivers/media/i2c/veyecam2m.ko
          license: GPL v2
          description: veyecam2m sensor v4l2 driver
          author: xumm <www.veye.cc>
          srcversion: 39B6CA03CC15515713EC3FC
          alias: of:NTCveye,veyecam2mC*
          depends: v4l2-async,videodev,v4l2-fwnode,mc
          intree: Y
          vermagic: 5.15.32-v7l SMP mod_unload modversions ARMv7 p2v8
          The capture code is taken from veye driver examples.
          Milan
            @milank I suspect that the FFC cable is not connected well enough. You could try replacing the FFC cable with a new one, or re-plugging it.
              Thank you.
              I reseated, no success.
              I bought a new FFC cable, and sadly, the issue persists.
              Milan
                @milank
                Hi, I can't judge remotely on this issue right now. Where did you order the camera ? Please private message me with the order number and I can arrange to get you a replacement.
                  I have happened to turn-off the wifi and switch to ethernet, just to see if there is any effect. To my surprise, camera is now providing a picture without these artefacts.
                  No idea if this is just a HW conflict or RF interference on the FFC cable.
                  Milan
                    @milank
                    I think it was RF interference on the FFC cable.
