    I2c tools failed
    3580
      veye_xumm @Viktor last edited by
      @viktor
      The parameters of the veye series are not as flexible as those of the cs series, and the parameter you want is mshutter.
      • V
        Viktor @veye_xumm last edited by Viktor
        Ok. Have tried mshutter, but shadows presents in all cases.
        If i write mshutter 0x46( 1/1000 ) i expect very short exposure and more dark image. It is ok because we are using light at night.
        But at daylight frame is over exposured. So works only 0x40 (auto shutter). Then at night we have this effect: http://forum.veye.cc/post/185
        Here is only mshutter auto:
        alt text
          @viktor said in I2c tools failed:
          Pls try close wdr as I suggested before.
          • V
            Wdr already closed.
            May be i should restart system?
            Pal i set before run programm.
            But other controls can i set before too?
              @viktor
              1. pls post your cmd to close wdr.
              2. pls try close 3d denoise.
              V 2 Replies Last reply Reply Quote 0
              • V
                • V
                  Here is cmd:
                  sudo ./veye_mipi_i2c.sh -w -f videoformat -p1 PAL
                  sudo ./veye_mipi_i2c.sh -w -f wdrmode -b 7 -p1 0x00
                  sudo ./veye_mipi_i2c.sh -w -f mshutter -b 7 -p1 0x40
                  alt text
                  So it is a daylight. Sensor has auto shutter mode, cars speed is slow because it is parking barrier.
                  Why is double image?
                    please add this one :
                    ./veye_mipi_i2c.sh -w -f denoise -p1 x00 -b7
                    • V
                      Thanks. Looks like fixed.
                      alt text
                        @viktor
                        OK. So 3D denoise is the key. You can try to have a low level 2d denoise.
                        • V
                          Thank you Meng.
                            @viktor
                            You are welcome.
