    veye_raspivid splits video in half and puts it together wrong
      raphael last edited by
      Hello
      when using veye_raspivid and using any other format then 1080*1920 it splits the video in half and display both halves wrong.
      1080p is behaving normally, but 720 is not.changed bitrate and other settings, but nothing changes the behaviour.
      this is 720x1280
      grafik
      this is 1080x1920
      grafik
      I've attatched the exact commands
      $ /usr/local/share/veye-raspberrypi/veye_raspivid -b 5120000 -w 1280 -h 720 -fps 30
      camera num -1
      Hardare version: 2a22082
      mmal: mmal_component_enable w 1280 h 720 fps 30
       raspipreview_create  com
      mmal: Splitter has 4 output port,you could use num 2,3 for extend
      $ /usr/local/share/veye-raspberrypi/veye_raspivid -b 5120000 -w 1920 -h 1080 -fps 30
      camera num -1
      mmal: mmal_component_enable w 1920 h 1080 fps 30
        veye_xumm @raphael last edited by
        @raphael
        What is the camera model you are using?
        First, you need to make sure that the camera supports the resolution you want to use.
        VEYE-MIPI-x does not support 720p resolution.
        Secondly, veye_raspivid does not configure the resolution of the camera, you need to configure the resolution using an i2c script and then use this resolution as a parameter in veye_raspivid.
          raphael @veye_xumm last edited by
          thanks for the answer, my seller listed 720p/60 and 1080/30 looks like he's wrong with that.
          (Imx290)
            @raphael correct
