SOLVED IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera
@maponarooo
If you have a soldering iron, of course, direct soldering to remove the device is the fastest. Otherwise you can wait a little for the official version of jetpack. -
@veye_xumm I have removed the part, but same...
$ gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY,width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)NV12" ! nv3dsink -e
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
Additional debug info:
gstv4l2src.c(660): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
Caught SIGSEGV
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
#0 0x0000ffffaa65ef08 in __GI___poll
#1 0x0000ffffaa78cb30 in () at /lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x0000ffffaa78cef0 in g_main_loop_run ()
#3 0x0000ffffaa92fac4 in gst_bus_poll
#4 0x0000aaaadbc84980 in event_loop
#5 0x0000aaaadbc838c8 in main (argc=<optimized out>, argv=<optimized out>)
Spinning. Please run 'gdb gst-launch-1.0 3567' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
What do I do?
@maponarooo
Please trydmesgcheck if any errors.
I guess it's a mipi transfer issue. Please check if the ffc cable connection is good?
Can you take a photo of the details at the connector for me to see? -
@veye_xumm I think so... A lot of erros have occured.
What's the matter?I have downloaded dtb file from here, is right?
https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/ v1.08$dmesg
[ 11.723697] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (49)
[ 11.724017] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 13.728334] bc00000.rtcpu:hsp-vm1: request 0x46000000: response timeout
[ 13.728577] bc00000.rtcpu:hsp-vm1: FW_HASH failed: 0xffffff92
[ 15.744350] bc00000.rtcpu:hsp-vm1: request 0x44bff000: response timeout
[ 15.744575] tegra186-cam-rtcpu bc00000.rtcpu: RTCPU trace: IOVM setup error: -110
[ 15.744789] tegra186-cam-rtcpu bc00000.rtcpu: trace boot sync failed: -5
[ 17.760379] bc00000.rtcpu:hsp-vm1: request 0x44bfef80: response timeout
[ 19.776342] bc00000.rtcpu:hsp-vm1: request 0x44bfec00: response timeout
[ 19.776636] tegra-ivc-bus bc00000.rtcpu:ivc-bus: IOVM setup error: -110
[ 19.776863] tegra186-cam-rtcpu bc00000.rtcpu: ivc-bus boot sync failed: -5
[ 19.777135] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=0 sha1=0000000000000000000000000000000000000000
[ 19.780143] tegra_aon c1a0000.aon: Adding to iommu group 5
[ 19.783372] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 19.785642] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 19.788426] denver_knobs_init:MTS_VERSION:53250041
[ 19.793245] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 19.793483] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 19.795579] t19x_cache tegra-cache: probed
[ 19.802597] nvpmodel: initialized successfully
[ 19.805375] trusty-irq trusty:irq: trusty_irq_create_irq_mapping failed (-22)
[ 19.805670] trusty-irq trusty:irq: failed to initialize irq 14, irq will be ignored
[ 19.806572] trusty-irq trusty:irq: trusty_irq_create_irq_mapping failed (-22)
[ 19.806860] trusty-irq trusty:irq: failed to initialize irq 15, irq will be ignored
[ 19.807257] genirq: Flags mismatch irq 10. 00004408 (trusty) vs. 00004408 (trusty)
[ 19.807445] trusty-irq trusty:irq: request_percpu_irq failed -16
[ 19.807617] trusty-irq trusty:irq: failed to initialize irq 29, irq will be ignored
[ 19.816117] trusty-virtio trusty:virtio: initializing.........
[ 22.356665] handlers:
[ 22.359314] [<00000000a96125ca>] tegra_mcerr_hard_irq threaded [<00000000453e20de>] tegra_mcerr_thread
[ 22.368379] Disabling IRQ #73
[ 22.371490] arm-smmu 10000000.iommu: Unexpected global fault, this could be serious
[ 22.379067] arm-smmu 10000000.iommu: GFSR 0x80000001, GFSYNR0 0x00000000, GFSYNR1 0x00000009, GFSYNR2 0x00000000
[ 22.389706] mc-err: (255) csr_nvdisplayr: EMEM address decode error
[ 22.389728] tegradccommon 15200000.display-hub: dma mapping done
[ 22.395405] mc-err: status = 0x20064092; addr = 0x ffffffff00; hi_adr_reg=0xff
[ 22.409216] mc-err: secure: yes, access-type: read
[ 22.423949] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1304000 KHz, changing to: 1344000 KHz
[ 22.426592] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40
[ 22.427181] irq: IRQ254: trimming hierarchy from :pmc@c360000
[ 22.427211] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 22.427274] sdhci-tegra 3400000.sdhci: BWMGR client registration for eMC Successful
[ 22.432996] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 22.438592] irq: IRQ255: trimming hierarchy from :pmc@c360000
[ 22.438834] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[ 22.443461] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 22.443466] usb 1-2: Manufacturer: Generic
[ 22.477139] hub 1-2:1.0: USB hub found
[ 22.477382] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 22.481102] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 255
[ 22.497718] mc-err: mcerr: unknown intr source intstatus = 0x00000000, intstatus_1 = 0x00000000............
[ 26.041038] veyecam 9-003b: probe failed VEYECAM_MODEL_ID_ADDR
[ 26.041924] veyecam 9-003b: board setup failed
[ 26.042845] veyecam 10-003b: probing v4l2 sensor
[ 26.043017] veyecam 10-003b: tegracam sensor driver:veyecam_v2.0.6
[ 26.056874] veyecam 10-003b: camera id is veyecam
[ 26.060518] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 26.062498] veyecam 10-003b: sensor is IMX385
[ 26.063356] veyecam 10-003b: board type is ONE board
[ 26.064574] tegra-camrtc-capture-vi tegra-capture-vi: subdev veyecam 10-003b bound
[ 26.066694] using random self ethernet address
[ 26.067608] using random host ethernet address
[ 26.085329] veyecam 10-003b: Detected VEYECAM sensor
[ 26.315653] tegra-hda 3510000.hda: Adding to iommu group 32
[ 26.316210] tegra-hda 3510000.hda: Override SDO lines to 4
[ 26.453528] nvadsp 2993000.adsp: Adding to iommu group 33
[ 26.453738] nvadsp 2993000.adsp: in probe()...
[ 26.454310] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 26.478915] tegra-asoc: sound: Adding to iommu group 33
[ 26.484139] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input7
[ 26.484400] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input8
[ 26.484620] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input9
[ 26.484796] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input10
[ 26.566201] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 33
[ 26.566257] tegra210_adsp_audio_probe: platform probe started
[ 26.567403] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 26.568483] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 26.569571] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 26.570751] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 26.571806] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 26.573328] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 26.573344] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 26.573349] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 26.579987] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 26.683224] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x5fd04000, fsynr=0x20012, cbfrsynra=0x1e, cb=31
[ 26.684453] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x5fd04000, fsynr=0x20012, cbfrsynra=0x1e, cb=31
[ 26.685526] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x5fd04040, fsynr=0x20012, cbfrsynra=0x1e, cb=31
[ 26.686589] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x5fd04080, fsynr=0x20012, cbfrsynra=0x1e, cb=31
[ 26.688021] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x5fd040c0, fsynr=0x20012, cbfrsynra=0x1e, cb=31
[ 26.689272] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x5fd040c0, fsynr=0x20012, cbfrsynra=0x1e, cb=31
[ 26.690298] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x5fd04100, fsynr=0x20012, cbfrsynra=0x1e, cb=31
[ 26.691320] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x5fd04140, fsynr=0x20012, cbfrsynra=0x1e, cb=31
[ 26.692764] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x5fd04140, fsynr=0x20012, cbfrsynra=0x1e, cb=31
[ 26.692842] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x5fd04180, fsynr=0x20012, cbfrsynra=0x1e, cb=31[ 27.757176] nvadsp 2993000.adsp: ADSP OS Hanged or Crashed! Restarting...
[ 27.758128] nvadsp 2993000.adsp: Dumping ADSP logs ........
[ 27.759262] nvadsp 2993000.adsp: End of ADSP log dump .....
[ 27.760045] nvadsp 2993000.adsp: dumping hwmailbox registers ...
[ 27.760054] nvadsp 2993000.adsp: recv_hwmbox(): 0x0
[ 27.760060] nvadsp 2993000.adsp: send_hwmbox(): 0x0
[ 27.760065] nvadsp 2993000.adsp: dumping fault frame...
[ 27.760892] nvadsp 2993000.adsp: r0 0x00000000 r1 0x00000000 r2 0x00000000 r3 0x00000000
[ 27.761744] nvadsp 2993000.adsp: r4 0x00000000 r5 0x00000000 r6 0x00000000 r7 0x00000000
[ 27.762602] nvadsp 2993000.adsp: r8 0x00000000 r9 0x00000000 r10 0x00000000 r11 0x00000000
[ 27.763530] nvadsp 2993000.adsp: r12 0x00000000 usp 0x00000000 ulr 0x00000000 pc 0x00000000
[ 27.764473] nvadsp 2993000.adsp: spsr 0x00000000
[ 27.765262] nvadsp 2993000.adsp: dumping arm mode register data...
[ 27.766037] nvadsp 2993000.adsp: fiq r13 0x00000000 r14 0x00000000
[ 27.766820] nvadsp 2993000.adsp: irq r13 0x00000000 r14 0x00000000
[ 27.767578] nvadsp 2993000.adsp: svc r13 0x00000000 r14 0x00000000
[ 27.768467] nvadsp 2993000.adsp: und r13 0x00000000 r14 0x00000000
[ 27.769204] nvadsp 2993000.adsp: sys r13 0x00000000 r14 0x00000000
[ 27.769961] nvadsp 2993000.adsp: abt r13 0x00000000 r14 0x00000000[ 31.712362] nvadsp 2993000.adsp: ADSP OS loading timed out
[ 31.713460] nvadsp 2993000.adsp: Unable to start ADSP OS
[ 31.714423] nvadsp 2993000.adsp: adsp failed to boot with ret = -62
[ 31.715415] nvadsp 2993000.adsp: Dumping ADSP logs ........
[ 31.716835] nvadsp 2993000.adsp: End of ADSP log dump .....
[ 31.717854] nvadsp 2993000.adsp: dumping hwmailbox registers ...
[ 31.717866] nvadsp 2993000.adsp: recv_hwmbox(): 0x0
[ 31.717874] nvadsp 2993000.adsp: send_hwmbox(): 0x0
[ 31.717880] nvadsp 2993000.adsp: dumping fault frame...
[ 31.718888] nvadsp 2993000.adsp: r0 0x00000000 r1 0x00000000 r2 0x00000000 r3 0x00000000
[ 31.719960] nvadsp 2993000.adsp: r4 0x00000000 r5 0x00000000 r6 0x00000000 r7 0x00000000
[ 31.721095] nvadsp 2993000.adsp: r8 0x00000000 r9 0x00000000 r10 0x00000000 r11 0x00000000
[ 31.722195] nvadsp 2993000.adsp: r12 0x00000000 usp 0x00000000 ulr 0x00000000 pc 0x00000000
[ 31.723240] nvadsp 2993000.adsp: spsr 0x00000000
[ 31.724192] nvadsp 2993000.adsp: dumping arm mode register data...
[ 31.725282] nvadsp 2993000.adsp: fiq r13 0x00000000 r14 0x00000000
[ 31.726304] nvadsp 2993000.adsp: irq r13 0x00000000 r14 0x00000000
[ 31.727314] nvadsp 2993000.adsp: svc r13 0x00000000 r14 0x00000000
[ 31.728334] nvadsp 2993000.adsp: und r13 0x00000000 r14 0x00000000
[ 31.729342] nvadsp 2993000.adsp: sys r13 0x00000000 r14 0x00000000
[ 31.733239] nvadsp 2993000.adsp: abt r13 0x00000000 r14 0x00000000[ 31.763421] nvadsp 2993000.adsp: ADSP has crashed too many times(1)
[ 31.796385] ADSP Driver is not initialized
[ 31.797365] ADSP Driver is not initialized
[ 31.798338] ADSP Driver is not initialized
[ 31.799251] ADSP Driver is not initialized
[ 31.811470] tegra210-adsp: probe of tegra210-adsp failed with error -62
[ 40.360373] [eqos_poll_for_swr][588][type:0x4][loga-0x0] poll_for_swr: timeout
[ 40.360639] net eth0: failed to poll MAC Software reset -
@maponarooo
What you post is the log of the system startup phase, which is normal.
What I want to see is that you execute gstreamer to try to PREVIEW first, then run dmesg and see the corresponding error report.I guess it's a mipi transfer issue. Please check if the ffc cable connection is good?
@veye_xumm When I look the ffc connection is fine.
This is gstreamer error log....
~$ gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY,width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)NV12" ! nv3dsink -e
Caught SIGSEGV
Waiting for EOS...
#0 0x0000ffff8b6ddf08 in __GI___poll
#1 0x0000ffff8b80bb30 in () at /lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x0000ffff8b80bef0 in g_main_loop_run ()
#3 0x0000ffff8b9aeac4 in gst_bus_poll
#4 0x0000aaaace904980 in event_loop
#5 0x0000aaaace9038c8 in main (argc=<optimized out>, argv=<optimized out>)
Spinning. Please run 'gdb gst-launch-1.0 2954' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.After, dmesg logs....
$dmesg
[ 153.864552] ------------[ cut here ]------------
[ 153.864582] WARNING: CPU: 4 PID: 2970 at /dvs/git/dirty/git-master_linux/kernel/nvidia/drivers/platform/tegra/rtcpu/capture-ivc.c:47 tegra_capture_ivc_tx+0x118/0x150
[ 153.864913] Modules linked in: fuse xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c br_netfilter lzo_rle lzo_compress zram overlay bnep aes_ce_blk crypto_simd rtk_btusb snd_soc_tegra186_asrc cryptd ofpart snd_soc_tegra186_arad snd_soc_tegra186_dspk snd_soc_tegra210_ope snd_soc_tegra210_mvc btusb snd_soc_tegra210_afc cmdlinepart snd_soc_tegra210_iqc aes_ce_cipher snd_soc_tegra210_dmic ghash_ce btrtl snd_soc_tegra210_adx input_leds qspi_mtd snd_soc_tegra210_amx sha2_ce btbcm sha256_arm64 snd_soc_tegra210_i2s snd_soc_tegra210_admaif snd_soc_tegra210_mixer mtd btintel snd_soc_tegra210_sfc sha1_ce snd_soc_tegra_pcm leds_gpio snd_soc_tegra210_adsp snd_soc_spdif_tx pwm_fan snd_soc_tegra_machine_driver tegra210_adma snd_soc_tegra_utils tegra_bpmp_thermal snd_soc_simple_card_utils snd_soc_tegra210_ahub max77620_thermal rtl8822ce nvadsp userspace_alert cfg80211 snd_hda_codec_hdmi
[ 153.865326] spi_tegra210_qspi veyecam(O) snd_hda_tegra snd_hda_codec snd_hda_core spi_tegra114 binfmt_misc loop nvgpu ina3221 ip_tables x_tables
[ 153.865380] CPU: 4 PID: 2970 Comm: v4l2src0:src Tainted: G W O 5.10.65-tegra #1
[ 153.865385] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 153.865392] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--)
[ 153.865401] pc : tegra_capture_ivc_tx+0x118/0x150
[ 153.865407] lr : tegra_capture_ivc_tx+0x2c/0x150
[ 153.865411] sp : ffff8000174837d0
[ 153.865417] x29: ffff8000174837d0 x28: ffff0000e8b25200
[ 153.865433] x27: 0000000040045612 x26: 0000000000000000
[ 153.865453] x25: 0000000000000118 x24: ffff0000eaa7b580
[ 153.865466] x23: ffff800017483900 x22: ffff0000bbb58e80
[ 153.865478] x21: ffff000083368400 x20: 0000000000000118
[ 153.865490] x19: ffff000083222080 x18: 0000000000000010
[ 153.865503] x17: 0000000000000000 x16: 0000000000000000
[ 153.865514] x15: ffff0000bbb593f0 x14: ffffffffffffffff
[ 153.865528] x13: ffff800097483627 x12: ffff80001748362f
[ 153.865549] x11: 69762d6572757470 x10: 61632d6172676574
[ 153.865562] x9 : 0000000000000000 x8 : ffff800017483a18
[ 153.865574] x7 : 000000000000ffff x6 : 0000000000000002
[ 153.865585] x5 : 0000000000000000 x4 : 0000000000000049
[ 153.865597] x3 : 0000000000000000 x2 : ffff8000101b6d10
[ 153.865612] x1 : 0000000000000000 x0 : 0000000000000000
[ 153.865630] Call trace:
[ 153.865638] tegra_capture_ivc_tx+0x118/0x150
[ 153.865645] tegra_capture_ivc_control_submit+0x34/0x60
[ 153.865653] vi_capture_ivc_send_control.isra.0+0x68/0x120
[ 153.865660] csi_stream_tpg_disable+0x70/0xb0
[ 153.865666] csi_stream_release+0x68/0xd0
[ 153.865673] vi_capture_shutdown+0x48/0xf0
[ 153.865680] vi_channel_close_ex+0x2c/0x80
[ 153.865697] vi5_channel_start_streaming+0x230/0x320
[ 153.865707] tegra_channel_start_streaming+0x50/0x80
[ 153.865721] vb2_start_streaming+0x6c/0x150
[ 153.865729] vb2_core_streamon+0x98/0x1a0
[ 153.865736] vb2_streamon+0x30/0x80
[ 153.865743] vb2_ioctl_streamon+0x54/0x60
[ 153.865750] v4l_streamon+0x3c/0x50
[ 153.865756] __video_do_ioctl+0x180/0x3f0
[ 153.865763] video_usercopy+0x27c/0x730
[ 153.865796] video_ioctl2+0x3c/0x180
[ 153.865803] v4l2_ioctl+0x64/0x90
[ 153.865810] __arm64_sys_ioctl+0xa8/0xf0
[ 153.865818] el0_svc_common.constprop.0+0x7c/0x1c0
[ 153.865828] do_el0_svc+0x34/0xa0
[ 153.865836] el0_svc+0x1c/0x30
[ 153.865852] el0_sync_handler+0xa8/0xb0
[ 153.865859] el0_sync+0x16c/0x180
[ 153.865865] ---[ end trace 077e1aa560ee9778 ]---
[ 153.865981] tegra194-vi5 15c10000.vi: IVC control submit failed
[ 153.866126] tegra194-vi5 15c10000.vi: csi_stream_release: failed to disable nvcsi tpg on stream 2 virtual channel 0
quad@quad-nx:~$ -
@maponarooo
I think this is caused by a mipi data parsing error.
It could be hardware or it could be a software reason.
You can follow this link https://elinux.org/Jetson/l4t/Camera_BringUp#Tips_for_debugging to check the mipi errror details, but I don't recommend it because everything is working fine on my end.
Here is my suggestion that- Check the hardware connection.
- If you have another motherboard, like raspberry pi or jetson other boards that can be used to test the camera, I suggest you test it first.
- re-burn the nx's system with sdk manager, then do the driver and dtb installation. In other words, start over with the software installation.
@veye_xumm I have tried my old jetPack 4.61 old image with same IMX385 camera board and Jetson Xavier. But it working well....
I think this is software problem.... -
@veye_xumm The manual is something wrong...
Pls check.3.5.3 Download the bsp package to the Jetson board
On Jetson Board:Or type in the address bar of your browser:https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
tar -xzvf nvidia_jetson_veye_bsp.tgz
But...
$ wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
--2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
Resolving github.com (github.com)... 20.200.245.247
Connecting to github.com (github.com)|20.200.245.247|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz [following]
--2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz
Reusing existing connection to github.com:443.
HTTP request sent, awaiting response... 404 Not Found
2022-08-15 20:03:06 ERROR 404: Not Found. -
@maponarooo
Thank you for the reminder, I've modified it.
The file should have a tar.gz suffix instead of tgz.
