    SOLVED Using veye-mipi-327 with opencv
      Nathan Sinclair last edited by
      I'm piping the contents of this command to a python program which accepts a numpy array for displaying to screen.
      veye_raspivid -t -1 -o -
      In what raw data format is this command transmitting raw video?
        veye_xumm @Nathan Sinclair last edited by
        @nathan-sinclair
        I think veye_raspivid transmitting h.264 encoded data.
        I think maybe V4L2 mode is a proper option.
        http://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi
          Nathan Sinclair @veye_xumm last edited by Nathan Sinclair
          Has issues running on pi zero. When installing:
          usage: sudo ./install_driver.sh veyecam2m/veye327/csimx307/cssc132
          Enable i2c0 adapter...
          ./install_driver.sh: line 81: 741 Segmentation fault sudo modprobe i2c-dev
          Add dtoverlay=veye327 to /boot/config.txt
          Add gpu=400M to /boot/config.txt
          Add cma=128M to /boot/cmdline.txt
          Installing the veye327.ko driver
          install: cannot stat './driver_bin/5.10.63+/veye327.ko': No such file or directory
          install: cannot stat './driver_bin/5.10.63+/veye327.dtbo': No such file or directory
          ./install_driver.sh: line 116: 769 Segmentation fault sudo /sbin/depmod -a $(uname -r)
            Nathan Sinclair @Nathan Sinclair last edited by
            @nathan-sinclair @veye_xumm
            Okay here's the progress i've made.
            command uses MJPEG codec and rgb rawformat.
            Pythoncode:
            start_pipe
            LiveCamera.pipe = subprocess.Popen(['/home/pi/veye/veye_raspcam/bin/veye_raspivid', '-cd', 'MJPEG', '-rf', 'rgb', '-n',  '-t', '0', '-o', '-'], stdout=subprocess.PIPE)
            read from pipe
            raw_image = LiveCamera.pipe.stdout.read(LiveCamera.width * LiveCamera.height * 3)
            a = raw_image.find(b'xffxd8')  # JPEG start
            b = raw_image.find(b'xffxd9')  # JPEG end
            if a != -1 and b != -1:
                jpg = raw_image[a:b + 2]  # actual image
                bytesarray = raw_image[b + 2:]  # other informations
                # decode to colored image
                image = cv2.imdecode(np.fromstring(jpg, dtype=np.uint8), cv2.IMREAD_COLOR)
            Doesn't read any data at the moment.
              @nathan-sinclair
              You can try using the D-SDK:
              http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_for_Raspberry_Pi#D-SDK
              program: capture2opencv or capture2opencv.py
              Of course veye_raspividyuv is another option.
              N 2 Replies Last reply Reply Quote 0
                @veye_xumm I think from previous correspondence capture2opencv was only capable of capturing 1 frame per second, we're needing a live feed. I should have said that earlier. I'll have a look at it though. Trying out the YUV. will report what i find.
                  I'm not familiar with the raspividyuv program.
                  I am using the following command piped to my python program:
                  LiveCamera.pipe = subprocess.Popen(['/home/pi/veye/veye_raspcam/bin/veye_raspividyuv', '-t', '0','-o', '-'], stdout=subprocess.PIPE)
                  Got it going but it appears only to run maybe a few frames per second.
                  Also I'm neeeding a time frame in order to get this working. It's very important that we get this flipping going for a client. To be specific:
                  We're using a pi zero with a usb camera and MIPI-327 and both of these cameras need to be able to be flipped in the event the camera goes upside down. We're using python because a library exists for it that allows us to display the video streams without a gui. Arducam software needs to be able to run at 30fps at 1080p.
                  Isn't MJPEG an option that can be used? i just need a way to get the right data from the mjpeg stream and then i'm okay.
                  What data is being sent based on the codec option MJPEG or H264. I just need to know where the data is and use opencv to convert it to an image.
                    @nathan-sinclair
                    1. You can use http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/ mirrormode function to set MIPI-327 output flip image. No need to flip it via opencv.
                    2. MIPI-327 output format is UYVY(a type of YUV422), which is not supported by opencv originally. Using the cpu to do the format conversion resulted in a lower frame rate.
                      If you just need PREVIEW, why not use veye_raspipreview? It also allows for display position adjustment scaling etc. without the need for a gui.
                      @veye_xumm I was just looking at the i2c program. Call this resolved.
