    SOLVED VEYE-MIPI-IMX327S and veye_mipi_i2c.sh on Google coral dev board issue.
      Nigel Gardiner last edited by
      Hi There
      I'm trying to use the I2c tool to control the VEYE-MIPI-IMX327s on the Google coral dev board.
      I downloaded veye_mipi_i2c.sh from your Github repository.
      But when I test it with ./veye_mipi_i2c.sh -r -f sensorid -b 1
      I get
      ./veye_mipi_i2c.sh: line 134: ./i2c_read: No such file or directory
      ./veye_mipi_i2c.sh: line 136: ./i2c_read: No such file or directory
      ./veye_mipi_i2c.sh: line 138: ./i2c_read: No such file or directory
      r sensor id is IMX7f7f; TWO board
      similarly if I test with ./veye_mipi_i2c.sh -r -f dhver -b 1
      I get
      ./veye_mipi_i2c.sh: line 121: ./i2c_read: No such file or directory
      hardware version is 0x7f
      I'm probably missing something or doing something totally wrong so any advice would be much appreciated.
      Am I meant to enable I2c as per the raspberry pi? I couldn't see a shell to do that in your repository.
      kind regards
      Nigel.
      veye_xumm N 2 Replies Last reply Reply Quote 0
        veye_xumm @Nigel Gardiner last edited by
        @nigel-gardiner
        I guess it could be that the command does not have execute permission.
        Try this
        chmod +x  i2c_read i2c_write
          Nigel Gardiner @Nigel Gardiner last edited by
          Hi
          Oh, my mistake I only downloaded veye_mipi_i2c.sh, I didn't realise it called i2c_read, i2c_write.
          Sorry I will download all files tomorrow and try again.
          thanks
          Nigel
