    SOLVED CS-MIPI-IMX307 camera Gstreamer UDP streaming error!
      maponarooo last edited by
      Hello~
      I want to use UDP streaming.
      This is my gstreamer command... but not working. error!!
      <Server Side>
      veye_raspivid -md 0 -p '0,0,1920,1080' -b 4000000 -t 0 -o -
      | gst-launch-1.0 fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! udpsink host=192.168.0.3 port=5321 sync=false
      <Client Side>
      C:\gstreamer\1.0\x86_64\bin\gst-launch-1.0 -v udpsrc port=5321 ! gdpdepay ! rtph264depay ! avdec_h264 ! autovideosink sync=false async=false
      ----- Error Msgs...
      Got context from element 'autovideosink0': gst.d3d11.device.handle=context, device=(GstD3D11Device)"(GstD3D11Device)\ d3d11device3", adapter=(uint)0, device-id=(uint)8066, vendor-id=(uint)4318, hardware=(boolean)true, description=(string)"NVIDIA\ GeForce\ GTX\ 1650";
      Pipeline is PREROLLED ...
      New clock: GstSystemClock
      ERROR: from element /GstPipeline:pipeline0/GstGDPDepay:gdpdepay0: Could not decode stream.
      Additional debug info:
      ../gst/gdp/gstgdpdepay.c(490): gst_gdp_depay_chain (): /GstPipeline:pipeline0/GstGDPDepay:gdpdepay0:
      Received a buffer without first receiving caps
      Execution ended after 0:00:00.023117200
      ERROR: from element /GstPipeline:pipeline0/GstUDPSrc:udpsrc0: Internal data stream error.
      Setting pipeline to NULL ...
      ../libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstUDPSrc:udpsrc0:
      streaming stopped, reason not-negotiated (-4)
      Freeing pipeline ...
      Pls. Help me....
        veye_xumm @maponarooo last edited by
        @maponarooo
        Hi,Please try the following cmd which works fine here on my stuffs.
        • veye_raspivid (stream over UDP using gstreamer)
          PC side,using gstreamer(Powershell recommended)
        RPI side
        ./veye_raspivid -b 4000000 -t 0 -o -  | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! udpsink host=x.x.x.x port=5000 sync=false
        H.264 encoding on bitrate 4Mbps.
        x.x.x.x is HOST PC IP address.You need to run the pc-side program first and then run the Raspberry Pi-side program.
          @maponarooo
          RPI side
            maponarooo @veye_xumm last edited by
            @veye_xumm Foolishly I got the server program running first.
            I run the client program first, then the server program, and it works fine.
            Anyway, thank you.
            It helped a lot.
              @maponarooo You are welcome.
