    SOLVED IMX307 Decimal Framerate
      MacDaddyFPV last edited by
      I am looking to add more settings support to openhd for the imx307 camera. I noticed that the newer firmware of the imx307 uses a decimal frame rate. Are you able to explain the difference between standard and decimal frame rate? Is it just 60fps would be 0.6 in decimal?
      Danny
        veye_xumm @MacDaddyFPV last edited by
        @MacDaddyFPV
        http://wiki.veye.cc/index.php/CS-MIPI-X_i2c#new_version_videofmt_write
        • 60fps
        ./cs_mipi_i2c.sh -w -f videofmt -p1 1920 -p2 1080 -p4 60.0
        • 0.5fps
        ./cs_mipi_i2c.sh -w -f videofmt -p1 1920 -p2 1080 -p4 0.2
          MacDaddyFPV @veye_xumm last edited by
          @veye_xumm thank you for the reply.
          I understand how to apply the settings.
          What I don't understand is what decimal settings can be used on the camera. What is the relation of decimal frame rate to standard frame rate?
          What decimal frame rate should be used for best performance on 1080p, 720p ?
            @macdaddyfpv
            @macdaddyfpv said in IMX307 Decimal Framerate:
            The decimal frame rate is an extension of the original function.
            It support finer parameter configuration. Support for frame rates less than 1, allowing for exposure times of more than 1 second.
            get and set current video format,for example:
            19201080@10fps
            1280
            720@60fps
            640*480@130fps
            This is the maximum frame rate supported by the CS-MIPI-IMX307 and is the default setting. I don't think it is necessary to modify the frame rate at all if not for longer exposure time for better low light effect.
              @veye_xumm thank you for the further explanation. After reading this and your previous post it makes sense now. Very Much appreciated.
                @macdaddyfpv You are welcome.
