    SOLVED CS-USB-IMX307 Linux Error
    USB camera
    • P
      patrick1957 last edited by
      使用在Ubuntu下, 系统可以检测摄像机设备,但它不能播放视频, 相机或驱动程序是否有问题?
      谢谢
      ffplay /dev/video0
      ffplay version 3.4.8-0ubuntu0.2 Copyright (c) 2003-2020 the FFmpeg developers
      built with gcc 7 (Ubuntu 7.5.0-3ubuntu1~18.04)
      configuration: --prefix=/usr --extra-version=0ubuntu0.2 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
      libavutil 55. 78.100 / 55. 78.100
      libavcodec 57.107.100 / 57.107.100
      libavformat 57. 83.100 / 57. 83.100
      libavdevice 57. 10.100 / 57. 10.100
      libavfilter 6.107.100 / 6.107.100
      libavresample 3. 7. 0 / 3. 7. 0
      libswscale 4. 8.100 / 4. 8.100
      libswresample 2. 9.100 / 2. 9.100
      libpostproc 54. 7.100 / 54. 7.100
      nan : 0.000 fd= 0 aq= 0KB vq= 0KB sq= 0B f=0/0
      sudo v4l2-ctl -d /dev/video0 --all
      Driver Info (not using libv4l2):
      Driver name : uvcvideo
      Card type : CS-USB-IMX307: UVC Camera
      Bus info : usb-0000:02:03.0-1
      Driver version: 4.18.20
      Capabilities : 0x84A00001
      Video Capture
      Metadata Capture
      Streaming
      Extended Pix Format
      Device Capabilities
      Device Caps : 0x04200001
      Video Capture
      Streaming
      Extended Pix Format
      Priority: 2
      Video input : 0 (Camera 1: ok)
      Format Video Capture:
      Width/Height : 640/360
      Pixel Format : 'YUYV'
      Field : None
      Bytes per Line : 1280
      Size Image : 460800
      Colorspace : Default
      Transfer Function : Default (maps to Rec. 709)
      YCbCr/HSV Encoding: Default (maps to ITU-R 601)
      Quantization : Default (maps to Limited Range)
      Flags :
      Crop Capability Video Capture:
      Bounds : Left 0, Top 0, Width 640, Height 360
      Default : Left 0, Top 0, Width 640, Height 360
      Pixel Aspect: 1/1
      Selection: crop_default, Left 0, Top 0, Width 640, Height 360
      Selection: crop_bounds, Left 0, Top 0, Width 640, Height 360
      Streaming Parameters Video Capture:
      Capabilities : timeperframe
      Frames per second: 30.000 (30/1)
      Read buffers : 0
      brightness 0x00980900 (int) : min=0 max=100 step=1 default=50 value=50
      contrast 0x00980901 (int) : min=0 max=100 step=1 default=50 value=50
      saturation 0x00980902 (int) : min=0 max=100 step=1 default=50 value=50
      hue 0x00980903 (int) : min=0 max=100 step=1 default=50 value=50
      error 5 getting ctrl White Balance Temperature, Auto
        veye_xumm @patrick1957 last edited by
        @patrick1957
        请问硬件是pc机吗?
        P 1 Reply Last reply Reply Quote 0
        • P
          patrick1957 @veye_xumm last edited by
          是的, 在PC Ubuntu 或 STM32MP157C-DK2 板OpenSTLinux, 两者都失败了
            客户已放弃此应用的研究。问题关闭。
