    SOLVED RPI Camera IMX327 different brightness values between startups
    2516
      veye_xumm @Seka last edited by
      @seka
      I see your question.
      There is no need to test with raspistill, the result should be the same as your python test.
      I have some test suggestions that you can try.
      1. Do not enable low_light mode.
      2. Increase the speed of ae adjustment at the beginning of your scripts.
      . / veye_mipi_i2c.sh-w-f aespeed-p1 0x64-p2 0x64
      It's just for the purpose of pure testing.
        Seka @veye_xumm last edited by
        @veye_xumm I just checked and another problem I have: I get no return value from the whitebalance mode and I cannot read its state also....
          Seka @Seka last edited by
          @seka Sorry, realised I had this error before: Problem: not current veye_mipi_i2c.sh ... solved now
            @seka with regarding to your suggestion " do not enable low_light mode": When I disable it, images are very dark.... and I already have longest shutter settings....
              @seka another problem that now occurs (and which has occured seldomly before): images are corrupted:
                @seka ok, I understand now what the problem is: os.system does not reliably execute shell commands. When executing directly in the terminal ---> problem is gone. Thank you
                  @seka
                  All problems sloved?
                    @veye_xumm No, but I am currently assessing wether it is a light source problem or camera problem. Will get back soon..
                      @seka Seems to be fixed right now
                        @seka OK~
