    SOLVED Veye_raspcam suite don't work with IMX327E
    • U
      UmbyWanKenobi last edited by
      Hello, good morning.
      Some time ago I bought this camera: VEYE-MIPI-327E (http://www.veye.cc/en/product/mipi-camera/veye-mipi-327e/#tab-id-2) with the intent of make it an allsky camera.
      Unfortunately, I have a way to make it work (and it's great) with gstreamer and that's it. I just can't get your Veye-room suite to work: I only have one laconic:
      "before create camera com time out
      Hardware version: d03114
      before create camera com "
      I attach some images for debugging Immagine 2021-08-09 105021.png Immagine 2021-08-09 110406.png Immagine 2021-08-09 110155.png Immagine 2021-08-09 105922.png Immagine 2021-08-09 105730.png Immagine 2021-08-09 105625.png Immagine 2021-08-09 105352.png
        veye_xumm @UmbyWanKenobi last edited by
        @umbywankenobi
        You can not use V4L2 mode and veye_raspicam mode at the same time.
        Because both want to control MIPI RX hardware.
        So, please uninstall v4l2 driver before using veye_raspipreview.
        U 1 Reply Last reply Reply Quote 0
        • U
          UmbyWanKenobi @veye_xumm last edited by
          @veye_xumm said in Veye_raspcam suite don't work with IMX327E:
          @umbywankenobi
          Hi!
          I was forced to use v4l2 as veye_raspicam doesn't give me any output.
          I tried not to have the veye327 driver loaded at boot, both the driver and vc4-fkms-v3d hoping it would make a difference, but it didn't. I still don't get any response from the veye_raspicam tools.
          But the veye_mipi_i2c.sh script to switch to night mode worked, a sign that the i2c commands are interpreted correctly.
          The kernel I use is "5.10.52-v7l +" and the RPI is an RPI4B 8G (d03114) Immagine 2021-08-10 090928.png Immagine 2021-08-10 091949.png
            @umbywankenobi
            please check this configuration :
            http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_for_Raspberry_Pi#RaspberryPi_System_Setup_and_Configuration
            and
            http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#RaspberryPi_Only.2C_Set_IO_config
            If all the configurations are correct, try taking a picture.
            ./veye_raspistill -o ~/test.jpg
              @umbywankenobi
              This question has been asked for a long time and the status has not been updated. I will mark the status as solved, so you can follow up again if needed, or just open the question.
