    SOLVED Direct download img from baidu
    2529
    • V
      Viktor @veye_xumm last edited by Viktor
      @veye_xumm I also have tried from host:
      copy dtb to kernel/dtb
      sudo ./flash.sh -r -k DTB jetson-nano-qspi-sd mmcblk0p1
      from L4T but nothing, /dev/video0 is not present.
      About system:
      cat /etc/nv_tegra_release
      R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t210ref, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
      number@number:~$ dpkg-query --show nvidia-l4t-core
      nvidia-l4t-core 32.4.4-20201016124427
      Bsp from here:
      https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/Nano/JetPack_4.4.1_Linux_JETSON_NANO_DEVKIT/dts dtb/VEYE-MIPI-327
      Kernel from here:
      https://github.com/veyeimaging/nvidia_jetson_veye_bsp/blob/master/kernel_image/Image_l4t_r32.4.4_veyecam.tar.gz
      So, please tell me how to repair Veye327 system after ubuntu software update?
      • V
        @veye_xumm Here is screenshot, after fresh installation, ubuntu wants 600mb updates, include nvidia l4t4.4: cam360.tv/etc/43-44.jpg
        So i need to update system without reflash as on other native jetson platforms.
        Please help.
          veye_xumm @Viktor last edited by
          @viktor
          If you want to upgrade new version of L4T, I suggest you upgrade the system first, then do our VEYE bsp upgrade.
          This is the list of version we provide:
          Jetpack4.2.2,L4T r32.2.1
          Jetpack4.3,L4T r32.3.1
          Jetpack4.4,L4T r32.4.3
          Jetpack4.4.1,L4T r32.4.4
          Jetpack4.5,L4T r32.5
          Jetpack4.5.1,L4T r32.5.1
          About your failure here:
          @viktor said in Direct download img from baidu:
          @veye_xumm Hi, have tried.
          cat /etc/nv_tegra_release -> r32, 4.4
          Download Image and dtb.
          Copy to /boot
          Edit /boot/extlinux/extlinux.conf -> FDT /boot/dtb file
          And now i have nvidia logo only and loop reboot.
          My system nano b01, imx327.
          Please check the dtb file name and the line you add in /boot/extlinux/extlinux.conf, they must be the same.
          • V
            Have build 4.5.1 from scratch and it works.
            About upgrade.
            Can i apply VEYE image/drivers without reflash and changing /app/home partition?
              @viktor
              http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2#Burning_the_prebuilt_Image_to_upgrade_Jetson_Nano_and_Xavier_NX_Devkit
              • V
                @veye_xumm Yes. It was first method what i did, but it does not work for Nano. Fdt line brokes system.
                  @viktor
                  pls paste your fdt line here. It must be wrong.
                  • V
                    It was:
                    FDT /boot/tegra210-p3448-0000-p3449-0000-b00.dtb
                    It must works?
                      @viktor
                      I think this line is correct.
                      It's very strange. It works normally in my place.
                      • V
                        @veye_xumm ok. Will try again.
