    SOLVED Python capture does not work with VEYE IMX462
      watchever last edited by
      Hi, I receive following error message when trying to call D_Capture method from python program on VEYE IMX 462
      mmal: mmal_port_connect: port 0x19120a0 is already connected
      mmal: mmal_connection_create: connection could not be made
      mmal: D_capture: Failed to connect camera video port to encoder input
      Segmentation Fault
      Preview works fine. I have tried several output formats I422, JPEG
      Following is my python code :
      buffer_array = self._camera.capture(encoding = 'jpeg')
      buffer_array.as_array.tofile(filename)
      self._camera.release_buffer(buffer_array)
      del buffer_array
        Just to add some more informations, is it possible to capture while preview is displaying with the libdmipicam library or do I need to stop preview before capture ?
          Ok just found the problem, need to stop_preview, make the capture then start_preview, as there is no port split on libdmipicam !
            @watchever
            You are right.
