    SOLVED Veye-raspipreview works at first run and not python demo and preview
      watchever last edited by
      I have several issues with my VEYE IMX462, first of all, when I start my raspberry and run python demo or preview the preview does not display. However when I run the veye-raspipreview first the display opens correctly and then after python demos and preview work. But I have to start first veye-raspipreview to make python demo and preview work. It is like veye-raspipreview init some parameters that are not by preview or libdmipicam.so... Any idea ?
      And more thing, as I told you last week for libveyecam.a library that has two differents versions in the github repository, it is the same for Raspicontrol.c, Raspicli.c, Raspipreview.c that are not the same inside D_mipi_rpi directory and inside veye_raspcam.
      It would be really helpful if we could find only one version of this files. Can you store them under a common directory for example ?
        @watchever said in Veye-raspipreview works at first run and not python demo and preview:
        VEYE-MIPI-IMX462 has an effective reset pin, please run this cmd to set reset pin high.
        ./rpi3-gpiovirtbuf s 133 1
        I add this function to veye_raspicam toolkit now, but not to python demo yet.
        Already done yesterday.
          Thanks xumm I have add rpi3-gpiovirtbuf initialize routine in the libdmipicam.so library, so don't need to run this binary alone and it works.
