    SOLVED Difference between libveyecam.a
      watchever last edited by
      Hi, there are two versions of the libveyecam.a static library on github, under /veye_raspcam/source and /D_mipi_rpi/libdmipicam.
      Which one should I use if I want to rebuild the libdmipicam.so library.
      They don't have same size and one seems more recent ?
        @watchever
        hi,
        pls use the one under /veye_raspcam/source ,that's the newer one.
          Thanks, maybe you should just put one version of this library on github to avoid any confusion.
            @watchever
            yes,you are right.
