    SOLVED veye327 failed on nano 2gb
    • V
      Viktor last edited by
      Hi Meng,
      I have Jetson Nano 2gb and veye327E and they works.
      Today i got another nano 2gb and it does not see veye327E.
      2 nano 2gb, 2 veye327E and veye327S, 2 sd cards works on first nano but not on new one.
      But imx219 works on new nano.
      Can you help to detect where is problem? (mipi, i2c, power ...)
      Best regards, Viktor.
        veye_xumm @Viktor last edited by
        @viktor
        You put the SD card on one nano that works well with the VEYE camera on another nano, and can't detect the VEYE camera?
        It is strange, please refer to the link below to check whether Image and dtb are correct.
        http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2#Are_Image_and_DTB_upgrade_successful_.3F
        • V
          Viktor @veye_xumm last edited by
          @veye_xumm Yes, same sd card works on one and do not on other. It is new nano from box. Will try to build sd from scratch.
          • V
            Viktor @Viktor last edited by
            @viktor I made new image with l4t 4.5.1 and sensor works now.
            It is strange.
              @viktor
              There is a very small number of 327s that enable reset pin, and this version of 327s works only with the latest drivers.
              We quickly realized this compatibility problem and soon disable 327s reset pin.
              • V
                @veye_xumm Ok, thanks.
