    I2c tools failed
    3544
    • V
      Viktor last edited by Viktor
      Trying to set fixed fps. First try to read:
      sudo ./veye_mipi_i2c.sh -r -f devid
      ====I2C write:<0x3b> <0x7> <0xfe>====
      device id is 0x 0
      Failed to write register index 0
      Device is on the bus 6 addr 3b present UU
      Have copied i2c folder from git bsp for veye and chmod +x.
      Dmesg:
      [25639.695508] i2c i2c-6: Setting clock rate 100000 on next transfer
      [25639.698513] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
      [25639.711008] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
      [25639.720439] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
      [25639.731618] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
      [25639.760191] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
      • V
        Viktor @Viktor last edited by Viktor
        Have added -d -b:
        sudo ./veye_mipi_i2c.sh -r -f devid -b 6 -d 0x3b
        device id is 0xc8
        sudo ./veye_mipi_i2c.sh -r -f hdver -b 6 -d 0x3b
        hardware version is 0xc8
        Direct bin run:
        out=$(./i2c_read 6 0x3b 0x01)
        echo $out
        Using i2C device /dev/i2c-6 ====I2C read:<0x3b> <0x1> <0x1>==== Read i2c addr 3B
        Tell me please, what is default AE/framerate state?
        • V
          Tried bus 7:
          sudo ./veye_mipi_i2c.sh -r -f devid -b 7
          device id is 0x 6
          sudo ./veye_mipi_i2c.sh -r -f hvdev -b 7
          sudo ./veye_mipi_i2c.sh -r -f hdver -b 7
          hardware version is 0x 3
          It works now.
          • V
            I wrote mshutter to 0x41 for constant 25 fps, am i right?
            Cause in low light i have high exposure.
            night
              veye_xumm @Viktor last edited by veye_xumm
              @viktor
              This camera is fixed frame rate. You do not need to change the exposure time for that.
              I suggest you use default parameters first, and change if necessary.
              Please use videofmt for 25fps. It is 30fps by default.
              http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/zh#videoformat
              • V
                Viktor @veye_xumm last edited by
                @veye_xumm Ok, I tryed wdmode, Pal and mshutter. And now it is good night picture.
                • V
                  Hi Meng,
                  Can you explain what parameter makes that effect with multiple shadows on image?
                  alt text
                    @viktor
                    Please try close wdr.
                    http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/zh#wdrmode
                    Because WDR uses two frames of data at different time points to be merged into one frame.
                    If the exposure time is long and the vehicle is fast, there will be problems in your image.You can also try to reduce ghosting by reducing the exposure time without turning off WDR.
                    • V
                      Viktor @veye_xumm last edited by Viktor
                      Ok, and which parameter controls exposure in i2c?
                      Like on CS?
                      ./cs_mipi_i2c.sh -w -f aetime -p1 XXX
                      range:(100,1/framerate]
                        @viktor
                        The parameters of the veye series are not as flexible as those of the cs series, and the parameter you want is mshutter.
                        • V
                          Ok. Have tried mshutter, but shadows presents in all cases.
                          If i write mshutter 0x46( 1/1000 ) i expect very short exposure and more dark image. It is ok because we are using light at night.
                          But at daylight frame is over exposured. So works only 0x40 (auto shutter). Then at night we have this effect: http://forum.veye.cc/post/185
                          Here is only mshutter auto:
                          alt text
                            @viktor said in I2c tools failed:
                            Pls try close wdr as I suggested before.
                            • V
                              Wdr already closed.
                              May be i should restart system?
                              Pal i set before run programm.
                              But other controls can i set before too?
                                @viktor
                                1. pls post your cmd to close wdr.
                                2. pls try close 3d denoise.
                                V 2 Replies Last reply Reply Quote 0
                                • V
                                  • V
                                    Here is cmd:
                                    sudo ./veye_mipi_i2c.sh -w -f videoformat -p1 PAL
                                    sudo ./veye_mipi_i2c.sh -w -f wdrmode -b 7 -p1 0x00
                                    sudo ./veye_mipi_i2c.sh -w -f mshutter -b 7 -p1 0x40
                                    alt text
                                    So it is a daylight. Sensor has auto shutter mode, cars speed is slow because it is parking barrier.
                                    Why is double image?
                                      please add this one :
                                      ./veye_mipi_i2c.sh -w -f denoise -p1 x00 -b7
                                      • V
                                        Thanks. Looks like fixed.
                                        alt text
                                          @viktor
                                          OK. So 3D denoise is the key. You can try to have a low level 2d denoise.
                                          • V
                                            Thank you Meng.
